NAS1966
Norbert Sliwinski
Monroeville
(24 posts)
08/11/2012 05:20PM
1973 MGB GM 2.8 V6
Fender flares
Posted by: NAS1966
Date: August 01, 2018 11:44AM
Hi y'all
would I need front and rear flares from Dodge Omni or just the rear from my 73 MGB?
Thanks
(3434 posts)
79 MGB, Buick 215
Re: Fender flares
Date: August 01, 2018 02:29PM
The Omni flared fender cars that I am familiar with, only used the front flares from the Omni/Horizon swapped to the opposite side of the car.
(2516 posts)
Re: Fender flares
Date: August 01, 2018 02:33PM
You can use either... but, the fronts are a lot less work. The rears have an inner fender/wheel well attached at the lip. To use them on the MG, you'd need to cut that away & trim it away for a neat look & no rough edges. 10 years ago, that probably wasn't worth the effort. Now that Omni's are a lot harder to find, it might be worth doing as one Omni while hard to find, will still be way easier to find than 2.
That said, VW rabbit flares are very similar & fenders are available new very reasonably.
NAS1966
Norbert Sliwinski
Monroeville
(24 posts)
08/11/2012 05:20PM
1973 MGB GM 2.8 V6
Re: Fender flares
Posted by: NAS1966
Date: August 02, 2018 09:41AM
Thank you for your replies - the inquiry was due to an ebay listing I found fo OMNI fender flares - check it out
New Universal Car Fender Flares 4 Piece Flexible Durable Polyurethane Body Kits
[www.ebay.com]
What do you think?
(2516 posts)
Re: Fender flares
Date: August 02, 2018 03:36PM
Not the same thing. Those are Polyurethane (plastic) bolt on flares. Dodge Omni flares are metal & part of the fender.
NAS1966
Norbert Sliwinski
Monroeville
(24 posts)
08/11/2012 05:20PM
1973 MGB GM 2.8 V6
Re: Fender flares
Posted by: NAS1966
Date: August 03, 2018 09:19PM
Thank you for your feed back - so, Rob mentioned using VW rabbit fenders? Would I need only front ones? Has anyone done those on the "How its Done" section?
(2516 posts)
Re: Fender flares
Date: August 03, 2018 09:31PM
There's a ton of info on Rabbit flares on this board. Just put "Rabbit flares" in the search box in the upper right of the page and you'll get at least a dozen threads. And yes, easiest would be to use all front fender flares - I've only seen new front fenders for sale. Haven't seen any rear quarters discussed.
NAS1966
Norbert Sliwinski
Monroeville
(24 posts)
08/11/2012 05:20PM
1973 MGB GM 2.8 V6
Re: Fender flares
Posted by: NAS1966
Date: August 09, 2018 04:45PM
I have looked and tried to find Rabbit fenders I can use - no luck Omni forget that - so I'll try to make my own using new shett metal and bending it to suit.
Thanks for all the tips.
(2516 posts)
Re: Fender flares
Date: August 09, 2018 05:07PM
There are at least two on eBay currently. But, if you have the ability to form your own, go for it. Way less expensive that way and you can make any size you want.
MGB SS
Joe Schafer
Central Michigan
(134 posts)
10/23/2007 06:46AM
1971 Mgb 1991 5.0 Ford
Re: Fender flares
Posted by: MGB SS
Date: August 09, 2018 10:00PM
Google 75 to 80 vw rabbit fender you will get more than you can count! Kinda a Rabbit thing ;)
(1894 posts)
Re: Fender flares
Date: August 10, 2018 10:16AM
From this site:
[forum.britishv8.org]
(1894 posts)
Re: Fender flares
Date: August 10, 2018 11:48AM
Here's another thread:
[www.mgexp.com]
(5567 posts)
Re: Fender flares
Date: August 10, 2018 03:51PM
I'm a firm believer in the "roll yer own" method, particularly the rear fenders. Done two sets of them now. If you were close enough I'd let you use my English wheel.
