Re: ATL Filler Cap
I used a Hagan fuel door and mounted it a bit higher than Paul did his, but concept is the same. I used some straight fuel filler hose I got from a local auto parts store & a couple of 45* stainless bends that I picked up from a mufler shop to make the bends. I had to do a bit of minor fabrication on the one that couples to the fuel tank to get the diameters to match.
Re: ATL Filler Cap
NAS1966 Norbert Sliwinski Monroeville (28 posts) Registered: 08/11/2012 05:20PM Main British Car: 1973 MGB GM 2.8 V6 |
Re: ATL Filler Cap
Thank you for all the input - I have dismantled a junk car and am using the components - pics will follow. I just finished mocking up relocating the tank. Moved it into the center since I will have a duel exhaust system.
