danielruhe
Daniel Ruhe
(3 posts)
05/23/2019 12:44PM
Mob steering column swap
Posted by: danielruhe
Date: May 29, 2019 03:44AM
Im looking to buy a later model steering column for my 1974 mgb 302 swap project. Is there any differences between the 1975-1980 mgb steering columns? Also, do the electrical components and steering lock/ignition directly transfer to the later model columns? And lastly, other than the firewall modifications is there anything else needed to bolt the column directly in place?
302GT
Larry Shimp
(201 posts)
11/17/2007 01:13PM
Re: Mob steering column swap
Posted by: 302GT
Date: June 28, 2019 08:08AM
All columns have the same dimensions at the rack end: 3/4 inch, 48 splines. They differ at the steering wheel end. 70-76 are all the same. 77-80 is different. The shaft where the steering wheel connects to can be interchanged between the two types of columns. The later columns did not have a central horn button, the horn was operated by the turn signal switch. However, parts are interchangeable. Still, it is easier to try to obtain a 741/2 through 76 column for your needs so as to avoid modifications..
