skootch13
aaron kuertz
cincinnati
(31 posts)
06/30/2020 01:50PM
1973 MGB Rover 4.6 (I'm told)
Edelbrock 1404 throttle linkage interferes with MG valve cover
Posted by: skootch13
Date: September 09, 2020 01:01PM
Offenhausere intake on a Rover V8.
Edelbrok 1404 carb.
Secondary throttle linkage is being prevented from opening all the way because of the valve cover.
Has anyone put a spacer on top of the intake manifold? I have a K and N air cleaner so I have an uncut stock hood. Clearance issues?
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Re: Edelbrock 1404 throttle linkage interferes with MG valve cover
Posted by: 88v8
Date: September 10, 2020 04:30AM
A phenolic spacer would be quite routine to prevent heat & fuel evaporation problems.
[www.summitracing.com]
Maybe yours doesn't have one precisely to avoid hood clearance issues.
There is an Offy manifold, the JWR/Offenhauser which is low rise. High torque. [www.woolfe.com] That's the one I'm using.
Air cleaners come in various thicknesses. I bought a 3" for my Rover V8, it was too tall, so I went to a thinner one. How thick is yours?
Ivor
skootch13
aaron kuertz
cincinnati
(31 posts)
06/30/2020 01:50PM
Date: September 10, 2020 07:44AM
A closer look shows that the linkage juuuust clears the valve cover. And that the problem for the secondaries not opening was a stretched or slipped throttle cable. Re adjusted and all is right with the world.
(4636 posts)
Date: September 10, 2020 11:45PM
If you have a cable, it's a good idea to protect it with an adjustable pedal stop. The design can be extremely simple. Typically, a strategically placed bolt and two nuts will do the trick.
IMHO, a proper throttle linkage is a very worthwhile upgrade.
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: September 11, 2020 04:24AM
Too right. Otherwise the cable will eventually break.
Mind you, if the pedal stop is attached to the pedal rather than the floor, that can have issues too. I recall a significant improvement in performance from removing multiple layers of carpet from under the stop.
Ivor
