johnsfolly John Deikis Chelsea, MI (2 posts) Registered: 08/10/2015 09:05PM Main British Car: 1979 MGB Roadster Buick 215 |
Re: MGB Wheel Hop
I will tag my question on this thread, since wheel hop and clutch dumping are mentioned....
I'm a relatively new owner although long-time into various MG cars. I have a 215 running through a T-5 and a stock MGB diff. I have been afraid to dump the clutch although I have been tempted. :-) So, can I DO that?? John |
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (5985 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Re: MGB Wheel Hop
You can, but just be aware that beating on it is likely to cause damage eventually, and the quality of your traction can make all the difference. So try to avoid it where either tire might lose traction and then grab. Like running over a pothole or patch of water for instance.
MGBV8 Carl Floyd Kingsport, TN (4014 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB, Buick 215 |
Re: MGB Wheel Hop
"I have a 215 running through a T-5 and a stock MGB diff. I have been afraid to dump the clutch although I have been tempted. :-)
So, can I DO that??" Not unless you don't mind breaking something. The MGB is not setup to launch hard. Needs some mods to be a drag car. The rearend is fairly stout, but some have broken spider gears. I cracked the bellhousing drag racing mine. Not much metal over by the clutch fork opening. |
