Goto Page: Previous12
Current Page: 2 of 2
johnsfolly
John Deikis
Chelsea, MI
(13 posts)
08/10/2015 09:05PM
1979 MGB Roadster Buick 215
Re: MGB Wheel Hop
Posted by: johnsfolly
Date: January 05, 2021 02:27PM
I will tag my question on this thread, since wheel hop and clutch dumping are mentioned....
I'm a relatively new owner although long-time into various MG cars. I have a 215 running through a T-5 and a stock MGB diff. I have been afraid to dump the clutch although I have been tempted. :-)
So, can I DO that??
John
(6469 posts)
Re: MGB Wheel Hop
Date: January 05, 2021 05:27PM
You can, but just be aware that beating on it is likely to cause damage eventually, and the quality of your traction can make all the difference. So try to avoid it where either tire might lose traction and then grab. Like running over a pothole or patch of water for instance.
(4512 posts)
Re: MGB Wheel Hop
Date: January 06, 2021 10:26AM
"I have a 215 running through a T-5 and a stock MGB diff. I have been afraid to dump the clutch although I have been tempted. :-)
So, can I DO that??"
Not unless you don't mind breaking something.
The MGB is not setup to launch hard. Needs some mods to be a drag car. The rearend is fairly stout, but some have broken spider gears. I cracked the bellhousing drag racing mine. Not much metal over by the clutch fork opening.
billymgb1000
bill gaulin
harrisville R.I.
(74 posts)
11/30/2012 12:31AM
1974 MGB V8 LS1 5.3
Re: MGB Wheel Hop
Posted by: billymgb1000
Date: February 15, 2021 07:54PM
You can do it a few times before something breaks unless you are unlucky. Then things will break right away!!! I have a LS 5.3 in mine and broke two MGB rear ends. They both took a good beaten before boom, So I have a ford 8 inch with a new 3.55 lsd posi no problems at least up till now, lol
Brittsonly
Dean Hickenlooper
(3 posts)
04/01/2016 08:17AM
Re: MGB Wheel Hop
Posted by: Brittsonly
Date: July 08, 2021 08:33PM
I fabricated these traction bars from 1.25” pipe and poly bushings from a MGB leaf spring.
LincTex
Lincoln Zaegen
(4 posts)
02/03/2021 06:54AM
79/80 MG MGB Stock 4 now
Re: MGB Wheel Hop
Posted by: LincTex
Date: January 05, 2022 11:23AM
( "Posted by: Brittsonly" )
How well do they work?
