donfaber Don Faber Columbus, IN (89 posts) Registered: 10/31/2007 10:53PM Main British Car: 1979 MGB 3.9L Rover V8 |
Pertronix Ignitor for Distributor
DiDueColpi Fred Key West coast - Canada (1349 posts) Registered: 05/14/2010 03:06AM Main British Car: I really thought that I'd be an action figure by now! |
Re: Pertronix Ignitor for Distributor
You have the small cap delco distributor.
PN 1181ls or 91181ls will fit.(1957 -1974 gm delco dist) However for a few dollars more you can get a brand new billet pertronix vacuum advance dist. complete with cap and rotor. Speedway has it for $288.00 Make sure to match up the coil, or use theirs to prevent burning out the module and preserve the warranty. Cheers Fred |
MGBV8 Carl Floyd Kingsport, TN (4366 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB Buick 215 |
I have been using my OEM 1963 Buick 215 distributor for 20 years without issue. The last 18 with a Pertronix module in it.
Just started installing the 91181LS ignitor in the Delco distributor installed in the 3.9L V8 - the screws that came out holding the points/condenser in place are a bit smaller than the new screws provided with the ignitor. And when I try to install the ignitor per Pertronix instructions (Location) it doesn't quite fit (but almost!). Any comments? I'd almost think the Delco Dizzy has metric dimensions while the pertronix ignitor is expecting english units? Suggestions, please.
Mine is the 91181 Ignitor II. Fit fine in my original Buick 215 dist. That was a long time ago. Heck, they may be made in China now.
If the unit does not line up with the holes in the breaker plate, I would pull that distributor & find the model numbers. You need to know exactly what it is. Might be an offshore Delco replacement? |
I mentioned the 91181LS doesn't fit in the Delco Remy installed. I've learned the braker plate came in multiple variations. In the attached pic, you can see the ground wire welded to the plate interferes with mounting the ignitor flat. There is also a pin to the left where the mounting screw should go. Any comments? There is no model number in the casting.
Breaker plate # is 1 M 7 1111007; Vacuum Advance is M 182 16 Any suggestions for replacing the whole dizzy in the 3.9L Rover shortblock that I bought in 2007? I've sent the unit to Jeff at Advanced Distributors for help. |
Moderator Curtis Jacobson Portland Oregon (4535 posts) Registered: 10/12/2007 02:16AM Main British Car: 71 MGBGT, Buick 215 |
Quote: You're in good hands. |
