donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
1979 MGB 3.9L Rover V8
Pertronix Ignitor for Distributor
Posted by: donfaber
Date: November 12, 2021 12:32PM
I have a 79B with 3.9L Rover V8 - it has what looks like a Delco-Remy Distributor, but no name tag that I can find. I want to install the Pertronix Ignitor. How can I find out what Distributor I have to properly select Pertronix parts?
(1389 posts)
Re: Pertronix Ignitor for Distributor
Date: November 12, 2021 05:48PM
You have the small cap delco distributor.
PN 1181ls or 91181ls will fit.(1957 -1974 gm delco dist)
However for a few dollars more you can get a brand new billet pertronix vacuum advance dist. complete with cap and rotor. Speedway has it for $288.00
Make sure to match up the coil, or use theirs to prevent burning out the module and preserve the warranty.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: November 13, 2021 09:28AM
Thanks!
(4615 posts)
Date: November 14, 2021 10:43AM
I would keep that Delco.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: November 14, 2021 02:15PM
That's my current plan....
(4615 posts)
Date: November 15, 2021 12:12PM
I have been using my OEM 1963 Buick 215 distributor for 20 years without issue. The last 18 with a Pertronix module in it.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: November 16, 2021 06:13PM
thanks, Carl
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: March 26, 2022 12:55PM
Just started installing the 91181LS ignitor in the Delco distributor installed in the 3.9L V8 - the screws that came out holding the points/condenser in place are a bit smaller than the new screws provided with the ignitor. And when I try to install the ignitor per Pertronix instructions (Location) it doesn't quite fit (but almost!). Any comments? I'd almost think the Delco Dizzy has metric dimensions while the pertronix ignitor is expecting english units? Suggestions, please.
(4615 posts)
Date: March 27, 2022 09:30AM
Mine is the 91181 Ignitor II. Fit fine in my original Buick 215 dist. That was a long time ago. Heck, they may be made in China now.
If the unit does not line up with the holes in the breaker plate, I would pull that distributor & find the model numbers. You need to know exactly what it is. Might be an offshore Delco replacement?
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: March 27, 2022 01:13PM
Thanks for the tips, Carl.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: April 15, 2022 08:37PM
I mentioned the 91181LS doesn't fit in the Delco Remy installed. I've learned the braker plate came in multiple variations. In the attached pic, you can see the ground wire welded to the plate interferes with mounting the ignitor flat. There is also a pin to the left where the mounting screw should go. Any comments? There is no model number in the casting.
Breaker plate # is 1 M 7 1111007; Vacuum Advance is M 182 16
Any suggestions for replacing the whole dizzy in the 3.9L Rover shortblock that I bought in 2007? I've sent the unit to Jeff at Advanced Distributors for help.
(4636 posts)
Date: April 16, 2022 12:51PM
You're in good hands.
