GTsRFine
David Maples
Georgia
(8 posts)
10/23/2007 01:43PM
74 MGBGT stock
Radiator mounting
Posted by: GTsRFine
Date: November 30, 2007 10:32AM
For those who have mounted their radiators with a forward or reverse tilt - Did you also angle the coolant inlet & outlet connections or did you let the rubber hoses take up the angle offset?
As you can tell from the question, I'm still fussing with various bracketry and different competing ideas for mounting the radiator and fan. BTW - a used Chevy Beretta electric fan seems to be perfect for matching the surface area of the early Mustang radiator I'm working with.
MGB SS
Joe Schafer
Central Michigan
(150 posts)
10/23/2007 06:46AM
1971 Mgb 1991 5.0 Ford
Re: Radiator mounting
Posted by: MGB SS
Date: November 30, 2007 08:48PM
David
I had my lower fitting moved to the other side for my application, so the Rad shop tilted it up for me, my upper is also tilted.
I used a elect fan from a Gm as well, the shroud that was on it was offset and wider than the Mustang Rad so I trimmed it and then split a piece of rubber hose to cover the cut edge, it works great.
Joe
ps:I was going to attach a photo but I seem to have a problem getting pictures onto this site, I think they are always to big sorry.
Edited 1 time(s). Last edit at 11/30/2007 08:54PM by MGB SS.
