Neil Verity
Neil Verity
(17 posts)
07/30/2008 02:47PM
Will a JAG IRS hub fit in a 16" wheel?
Posted by: Neil Verity
Date: April 17, 2009 12:29PM
Hi,
Quick question, Does the stock JAG IRS hub fit into a 16" wheel? I have options on wheel size (16" or 17"), but would prefer to use the 16" wheel since slicks are about $100.00 apiece cheaper than 17" slicks and of course the car could be lower to the ground. Ideally, I don't want to be limited on backspacing, when considering wheel diameter (probably use an 11" wide wheel) which of course can only tuck under the car so much before inner fender/frame rails become an issue, but per class rules I can have up to a 64" track.
P.S. Jim, your threads on the 340 and roadmaster builds have been very helpful....just coudn't see if the 16" wheel would work.
Neil
Re: Will a JAG IRS hub fit in a 16" wheel?
Date: April 17, 2009 01:00PM
It will depend on the wheel. In most cases it will probably work but you'll have to watch the pivot shaft nuts. 17's will definitely work.
Neil Verity
Neil Verity
(17 posts)
07/30/2008 02:47PM
Date: April 17, 2009 02:38PM
Jim,
Thanks. I also think it will work by my measurments with the REAL (thats a brand) wheels I have in mind but have yet to purchase.
Thanks again
Neil
Date: April 17, 2009 06:32PM
If you can get measurements from the company, do that. I know the inside diameter on my wheels tapers as you move inboard from the inner lips. so what fit's inside the wheel by the inner lips doesn't fit by the time you get to the surface the hub mates to.
