jbarila John Barilaro Red Sox Nation! (60 posts) Registered: 11/02/2007 08:29AM Main British Car: 1977 MGB Ford 302/5L |
Wheel Question
Would a 15"x7" 4lug x 4-1/2 with 0 mm offset and 4" of backspace work?
I know wheel threads go on forever but I have a chance to get a nice set cheap. But once I have them shipped I own them. Thanks, JB Edited 1 time(s). Last edit at 04/29/2009 02:19PM by jbarila. |
Re: Wheel Question
Mike's correct - I have 15x7 Panasports with 22mm offset (std MGB) on a Ford axle that is the same width as the std "B" axle and they are close to optimal for fitting in the wheelwell.
Re: Wheel Question
If your axle is a std width "B" axle , then you will have no problem with inner well interference by using those 4" backset wheels - you will, of course, have to flare the fenders.
Re: Wheel Question
When you say offset, is the offset + or - in another words is the offset on the face of the wheel or back of the wheel.
Many companies now days they refer to + offset sue to the FWD wheels. The best way is to measure your backspace (offset in the back of the wheel) and order a set with the same. this will help you. [www.rsracing.com] |
