pac11adp Mike Kaban Powell River B.C. Canada (7 posts) Registered: 03/03/2009 09:49PM Main British Car: 78 MGB Mazda 12a rotary |
Thanks for the help a few months ago here is the completed Mazda 12a Rotary project
I posted here back in march asking about this swap... anyways it turned out great, lots of power and way more power down low than I thought it would have. 2 resonators, big pipe and a free flowing muffler, pretty deep sound for a rotary. Cut the front cross member on an angle and plated it in with 1/4 " steel, engine really low and as far fwd as I could. Shifter ended up in almost exactly the same spot as stock... just had to make the hole a bit bigger. Solid front mount, rubber trans mount no vibration felt anywhere :) Just need to put some hose on the heater now
Edited 1 time(s). Last edit at 07/11/2009 07:18PM by pac11adp. |
Bugeyev8 Brian Marshall San Leandro CA (32 posts) Registered: 12/16/2008 08:53PM Main British Car: 1960 Bugeye, 1974 MGB,Triumph TR8 1.2 115 Hp 1275 in the Bugeye, Nissan Ka24DE in MG |
Re: Thanks for the help a few months ago here is the completed Mazda 12a Rotary project
those mufflers will not last long on there with the heat from the rotary, when they burn out use the borla ones or the ones with vocanic rock inside, Don't ask me how I know...
you will also need to run a factory Mazda Roraty oil cooler if you want that engine to live |
It's a '85 12a. In 84 and 85 mazda used an oil to water cooler under the engine oil filter. We're running pre mixed 2 stroke oil in the fuel instead of the stock oil injection so that lets you use synthetic oil. Since I'm more concerned about engine life and power and not too concerned about the emissions we're running a 160 thermostat. The temp gauge hardly moves.
I agree with you on the 2 bottles though. I told the muffler shop that glass packed bottles won't last they didn't believe me. The muffler is not packed and is a used one out of the RX7. |
