Trooper Kenneth Frasier Huntingtown,Maryland (13 posts) Registered: 08/20/2009 07:12PM Main British Car: 1974 TR-6 |
Re: Hello, help!!!
Thank you! That sounds like the route to go no need to buy something that I do not really need. Well I guess I have to go to work. But I will be thinking about what to do next. Why do I have to have a job to build a car? LOL Will talk to you soon. Hope you feel better soon.
Re: Hello, help!!!
The TR6 body isn't that heavy (about 300#), but it isn't that strong either. These things have the structural integrity of spaghetti. Before you take it off the frame, remove the doors and brace the door openings. Use the hinges and the screw for the door striker plates. Cross brace that bhind the CG to give you somewhere to lift. Use this and the lifting holes under the hood - if they aren't rotten.
If you are doing bodywork and aren't an expert do ONE PIECE AT A TIME (I'm shouting deliberately). Don't whatever you do get all excited and split the body (which at least one of the resto manuals tells you to do). You will have the devil of a time getting it all back together and aligned. Also note that some of the aftermarket panels are a lousy fit. In many cases you are going to be better off getting good used panels if you can find them. Regardless of what you do, expect to spend a lot of time getting the panel gaps looking right. If you do, the reward is a great looking car. Lose patience and no matter how good the paint is, it'll still look half assed. Edited 1 time(s). Last edit at 07/14/2010 10:03PM by alana. |
Re: Hello, help!!!
Well I am back with a update. I replaced both outer sill and inner sill. Did a littler work on the floorpans. I found a shop that does acid dipping. So as of last week I dropped the car off and should get it back on Jan. 17. It will be going right to the paint shop for metal washing and primer coat. I will put up some pictures this weekend. I will also take a few pictures when I pick it up.
