Nice new photos of Ken's TR6...
...have been added to the photo gallery!
Here's the link: Ken Hiebert's 1972 TR-6 with 1994 GM "LT1" 5.7L EFI Engine (42 photos) Here are just two samples: |
Re: Nice new photos of Ken's TR6...
Ken, Would you elaborate on the front disc conversion? Is that a Willwood disc and mounting redrilled to attach as the original Triumph disc?
Thanks, Dennis |
Hi Dennis,
Yes, I could elaborate. Here's the whole gamut. Like everything else on this car, the performance parts had to be custom made either because they don't make them or I was too cheap to buy them. Basically, this is a Wilwood disc mounted on a custom made "hat" then bolted to the TR6 hub.Parts from Wilwood: 120-6811 Caliper-Forged Dynalite-1.62" Pistons-.81" Disc 160-0277 Rotor-UL32 Vented Iron-12.19x.810-8 on 7.00" 15Q-6824K PolyMatrix Pad Set-7112Q-DL11-BDL-FDL Basically, I purchased the caliper, rotor and the material for the hat first. My friend and I fabricated the hat on the milling machine from 1/2" plate then I fabricated the caliper adapter to suit the spacing and diameter. Hats fabricated from 1/2" plate aluminum See next post- |
Dennis,
Disassembled bracketry caliper mounts with 1/8" secondary brackets assembly before bolts are trimmed to length and nuts are installed Side view. You can see with the primary bracket, on how it was spaced away from the TR6 caliper mount to account for the rotor How does it perform? Great! All the braking power this car will ever need. This particular caliper matched well with the stock TR6 master cylinder. I have to give much credit to Dale Knapke (tr6turbo). He installed a similar system and helped me out alot. |
Ken,
Thanks for your detailed reply, I appreciate it very much! Now if I can do something constructive and pass it on to the group. -Dennis |
