Triumph Sports Cars
austingh
Austin Haynes
Colorado USA
(6 posts)
11/27/2009 02:16PM
1976 SPITFIRE 1500, 1964 ASTON MARTIN DB3
I want a new engine for my 76 Spit
Posted by: austingh
Date: November 27, 2009 02:46PM
I have a 76 spitfire 1500 and I need a little more... "oompf." Funds are limited at the moment but I have plenty of time. I am mechanically challenged but have plenty of good buddies who know a thing or two. Any ideas on what to put in the front end? please help
austingh
Austin Haynes
Colorado USA
(6 posts)
11/27/2009 02:16PM
Re: I want a new engine for my 76 Spit
Posted by: austingh
Date: November 27, 2009 02:53PM
As a side note: I am 22 (next gen of spit lover). Had a 72 MG B in the past and hated to part with it. I am new to this forum and excited to learn about brit racing cars.
alana
alan atkinson
10567
(232 posts)
06/19/2008 08:06PM
68 TR250 LS2
Posted by: alana
Date: November 29, 2009 08:45PM
Saw a 2.3 Ford engine in one at Carlisle a couple of years back that fit pretty nicely in there. One small notch to the firewall/frame to get the (stock) headers through, otherwise it fit right in there. Afaik the engines aren't expensive either.
turbospitfire
Max Brewster
(49 posts)
04/25/2008 01:05PM
1979 Triumph Spitfire Ford 2.3 Liter Turbo
Posted by: turbospitfire
Date: November 30, 2009 11:09AM
Hi Austin, I'm partial to 2.3 ford motors also. Check out my write up and David Stutz too. You will see that bonnet modification is required.
[www.britishv8.org]
[www.britishv8.org]
Cheers,
Max
austingh
Austin Haynes
Colorado USA
(6 posts)
11/27/2009 02:16PM
Posted by: austingh
Date: December 02, 2009 03:50PM
Found a cheap engine in a Toyota Celica that starts at 120 hp and we are going to super charge/turbo charge, stoke and boost to about 400 hp. have to replace the rear end and suspension... only thing left that is Spit might be the frame and body... maybe the wheels too... So many options. Thanks for your help
austingh
Austin Haynes
Colorado USA
(6 posts)
11/27/2009 02:16PM
Posted by: austingh
Date: December 06, 2009 09:42PM
changed my mind about the celica engine... we found a suitable modification that is a little bit... different. We are put a GSXR 1000 motorcycle engine in the vehicle with an electric reverse... Its going to be quite the conversion... will put pics up as soon as i take em
Date: December 07, 2009 12:01AM
Now that sounds like quite the set-up. Should be a ton of fun.
motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
1967 Morris Minor (48 hp @ crank!), 1971 TR6 302
Posted by: motek
Date: December 11, 2009 08:27PM
I had a GSX 750. Tons of hp but aren't you worried you will have no torque? Winding it out to 14K at stop lights might get old.
austingh
Austin Haynes
Colorado USA
(6 posts)
11/27/2009 02:16PM
Posted by: austingh
Date: December 31, 2009 03:33PM
yeah... torque is an issue... maybe i will use the ford mustang v8 motor. budget is tight lately and i am rethinking the gsxr motor. any suggestions?
motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
Posted by: motek
Date: January 01, 2010 06:15PM
I'm planning a 302 in my TR6, but for the spitfire I would use the Ford 2.3L.
austingh
Austin Haynes
Colorado USA
(6 posts)
11/27/2009 02:16PM
Posted by: austingh
Date: January 14, 2010 09:46AM
well i finally settled on an engine - the 1985 22re. we have replaced the rear end with a toyota celica's and upgraded the engine and transmission to about 250 hp.
maganoo82
kyle micou
clarksville VA
(4 posts)
01/14/2010 09:33PM
2 Spits, 2 MGBs, 2 MGB GTs, and a TR7 several
Posted by: maganoo82
Date: January 14, 2010 11:09PM
Just out of curiosity, did you consider the Toyota 4AGE out of the old rear drive Corolla? Searches online will find motors for as little as $400 and 5 speeds for them can be found almost everywhere. The motor itself is tiny and light and has potential for serious power, Atlantic Series cars used 250 NA versions and the little 1.6L will handle decent boost too. Just asking because that is my plan with my 79 Spit.
Sparrow010
Andrew Gaskin
New Zealand
(25 posts)
06/06/2009 08:04PM
1974 Triumph Stag Toyota 1 - UZ - FE Quad cam 4.0
Posted by: Sparrow010
Date: October 01, 2010 07:42AM
Am fitting a Toyota 1600 4AGE with T 50 to my Mk4 at the moment. Think it will be a sweet conversion.
