austingh Austin Haynes Colorado USA (6 posts) Registered: 11/27/2009 02:16PM Main British Car: 1976 SPITFIRE 1500, 1964 ASTON MARTIN DB3 |
I want a new engine for my 76 Spit
I have a 76 spitfire 1500 and I need a little more... "oompf." Funds are limited at the moment but I have plenty of time. I am mechanically challenged but have plenty of good buddies who know a thing or two. Any ideas on what to put in the front end? please help
Re: I want a new engine for my 76 Spit
As a side note: I am 22 (next gen of spit lover). Had a 72 MG B in the past and hated to part with it. I am new to this forum and excited to learn about brit racing cars.
Saw a 2.3 Ford engine in one at Carlisle a couple of years back that fit pretty nicely in there. One small notch to the firewall/frame to get the (stock) headers through, otherwise it fit right in there. Afaik the engines aren't expensive either.
turbospitfire Max Brewster (49 posts) Registered: 04/25/2008 01:05PM Main British Car: 1979 Triumph Spitfire Ford 2.3 Liter Turbo |
Hi Austin, I'm partial to 2.3 ford motors also. Check out my write up and David Stutz too. You will see that bonnet modification is required.
[www.britishv8.org] [www.britishv8.org] Cheers, Max |
Found a cheap engine in a Toyota Celica that starts at 120 hp and we are going to super charge/turbo charge, stoke and boost to about 400 hp. have to replace the rear end and suspension... only thing left that is Spit might be the frame and body... maybe the wheels too... So many options. Thanks for your help
changed my mind about the celica engine... we found a suitable modification that is a little bit... different. We are put a GSXR 1000 motorcycle engine in the vehicle with an electric reverse... Its going to be quite the conversion... will put pics up as soon as i take em
Now that sounds like quite the set-up. Should be a ton of fun.
motek George Smathers Spokane, WA (118 posts) Registered: 09/12/2009 02:45PM Main British Car: 1967 Morris Minor (48 hp @ crank!), 1971 TR6 302 |
I had a GSX 750. Tons of hp but aren't you worried you will have no torque? Winding it out to 14K at stop lights might get old.
yeah... torque is an issue... maybe i will use the ford mustang v8 motor. budget is tight lately and i am rethinking the gsxr motor. any suggestions?
I'm planning a 302 in my TR6, but for the spitfire I would use the Ford 2.3L.
well i finally settled on an engine - the 1985 22re. we have replaced the rear end with a toyota celica's and upgraded the engine and transmission to about 250 hp.
maganoo82 kyle micou clarksville VA (4 posts) Registered: 01/14/2010 09:33PM Main British Car: 2 Spits, 2 MGBs, 2 MGB GTs, and a TR7 several |
Just out of curiosity, did you consider the Toyota 4AGE out of the old rear drive Corolla? Searches online will find motors for as little as $400 and 5 speeds for them can be found almost everywhere. The motor itself is tiny and light and has potential for serious power, Atlantic Series cars used 250 NA versions and the little 1.6L will handle decent boost too. Just asking because that is my plan with my 79 Spit.
Sparrow010 Andrew Gaskin New Zealand (25 posts) Registered: 06/06/2009 08:04PM Main British Car: 1974 Triumph Stag Toyota 1 - UZ - FE Quad cam 4.0 |
Am fitting a Toyota 1600 4AGE with T 50 to my Mk4 at the moment. Think it will be a sweet conversion.
