en ian jenkins Mississauga Ont canada (67 posts) Registered: 12/27/2010 11:06AM Main British Car: 77 tr7 |
rover EFI into tr7
I did a search here but didn't see an answer
I have a '92 rover system i'm putting into a tr7 What re my options for oil pressure and coolant temp gages? The sensors on the engine are BSP? What have others done with this? thank you |
Re: rover EFI into tr7
You would be surprized but the TR7 and TR8 temp sender and gauge are the same. You can find a port on the Rover EFI intake to put the sender in. The oil pressure on a TR7 is only a warning light and also on a rover timing cover there are enough ports for you to use a single prong oil pressure swith in the stock TR7 harness. Other sensors such as cold start, temp, etc you will need to have the whole harness or go with an aftermarket EFI control system.
Is it a TR7 one? I have about 3 of them used............ message me.
