Re: Stag Engines
Stags usually get Rover transplants. Looks like there is plenty of room in there for a Ford 302 or even a Chevy LS engine, if not interested in the Rover 3.5/3.9/4.6 variants. Will it have a manual or automatic tranny?
Re: Stag Engines
Re: Stag Engines
Re: Stag Engines
It's a pretty heavy engine. What is your budget? LS perhaps?
JB |
Re: Stag Engines
Thanks, BlownMGB-V8
I am restoring this car for a family friend who is a collector. Budget is always a concideration but not an issue. We're mostly looking for easiest drop in and maintenance, this car may end up belonging to his son. Thanks |
Re: Stag Engines
LSx are the LS series of engines. The first one (Hence LS-1) came in the C5 Vette and Camaro SS (plus some others).
BOPR is Buick/Oldsmobile/Pontiac/Rover. Its shorthand for all the iterations of the 215 engine that pretty much every British v8 that isn't the Stag has been made from. [en.wikipedia.org] [en.wikipedia.org] |
Re: Stag Engines
I'd go with the Rover if you want to stay British, and use one of the newer fuel injected engines for driveability and such, or with the LS series for better power and economy and perhaps longevity. The Rover swap is likely to be the easiest just because that is the most common swap for the Stag so the parts should be available. The LS will have the most wow factor.
JB |
Re: Stag Engines
Thanks, Blown MGB-V8 and Alana
Jim, when you mention the Rover Swap are you talking about the BOPR 215 engine? Which engine will offer the more space after installation LS or BOPR? Thanks. |
Re: Stag Engines
[paceperformance.com]
[www.v8register.net] The second one is in mm - translates to roughly 30.5w 33.75l 28.25h In other words they are very close... |
Re: Stag Engines
Rover=BOPR.
In fitment the difference is that the parts are available for the BOPR. For the LS you have to make things like engine mounts and headers. Also pay attention to coolant lines, etc. JB |
Re: Stag Engines
Thanks, Jim and Alan
I am going to see the owner of this "light at the end of the tunnel" and discuss all of this with him. How do you find the parts for putting a BPOE in a stag? Thanks |
Sparrow010 Andrew Gaskin New Zealand (25 posts) Registered: 06/06/2009 08:04PM Main British Car: 1974 Triumph Stag Toyota 1 - UZ - FE Quad cam 4.0 |
Re: Stag Engines
Re: Stag Engines
"How do you find the parts for putting a BPOR in a Stag?"
One good place to start is this message board's classified section. A number of Stag specific parts are listed and shown in this recent ad: [forum.britishv8.org] - check out those sexy Stag-specific stainless steel headers! You can also post "wanted" ads in the classified section. |
StagByTriumph Glenn Merrell Colorado (37 posts) Registered: 10/25/2007 12:11PM Main British Car: 1973 Stag Rover SD1 3.5 w/ 3.9 EFI |
Re: Stag Engines
Andy,
That conversion is absolutely gorgeous! Now where did you get those camber adjustment brackets? Glenn |
