Triumph Sports Cars
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
A Day of 8-Therapy
Posted by: WedgeWorks1
Date: May 28, 2011 08:23PM
Went to my friends place to help him with his and others TR8s. His gold convertible I put a new cloth Robbins top on. The green TR8 needed a gas tank then a tune up. The orange TR8 just needed to be seen and admired for being a $100 TR8 coupe that was almost written-off now that it is officially on the road.
http://i1012.photobucket.com/albums/af242/wedgeworks/TR8s/DSC00849.jpg
http://i1012.photobucket.com/albums/af242/wedgeworks/TR8s/DSC00848.jpg
Before.....
http://i1012.photobucket.com/albums/af242/wedgeworks/TR8s/IMG00895-20110326-1247.jpg
After......
http://i1012.photobucket.com/albums/af242/wedgeworks/TR8s/DSC00845.jpg
(4514 posts)
Re: A Day of 8-Therapy
Date: May 29, 2011 09:53AM
Mike,
Nothing like V8 weekend to brighten your spirits!
What size wheels & tires on the green TR8?
WedgeWorks1
Mike Perkins
(460 posts)
07/06/2008 08:07AM
Date: May 29, 2011 08:43PM
They are compomotive 15x7s. The gold car are 17x6 fronts and 17x8 rears.
(4514 posts)
Date: May 31, 2011 08:24PM
So there is hope for decent size wheels & tires for the TR7/8.
WedgeWorks1
Mike Perkins
(460 posts)
07/06/2008 08:07AM
Date: June 01, 2011 08:31AM
There is but some serious inner fender lip and body triming to make them work. I do feel bad for the front wheel bearings.....so small for such a big tire but he is all straight line.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: June 01, 2011 10:40AM
I'm running 16X8s on my car and could have easily gone as big as 16X10s on the back. Fender rolling and even fender stretching, coil over struts, and different wheel bolt patterns help in the quest. Without these mods, the best you can do is a 15X7 and 205 tires. I got around the small wheel bearing and difficult bolt pattern by installing a Ford rear end and modified Rover SD1 front struts. If anybody has a set of the SD1 struts laying around they want to sell, I'd be interested. Several of my buddies want to copy this setup, but can't find the used struts and hubs.
djw090
David Witham
Warwick UK
(115 posts)
06/12/2008 11:20AM
MGB 1974 and MG ZT 160 turbo 2005
Posted by: djw090
Date: June 01, 2011 11:30AM
The wheels from an MGF bolt straight on. In TF guise these go up to 16 inch.
bsa_m21
Martin Rothman
Vancouver, Canada
(216 posts)
01/06/2009 11:41AM
1980 TR7V8 Rover 3.9L
Posted by: bsa_m21
Date: June 02, 2011 08:51AM
Todd,
What has to be modified to make the SD1 struts fit?
Martin
Re: A Day of 8-Therapy, struts ?
Date: June 02, 2011 11:58AM
If one wanted a 5 on 4.5" bc., light weight, strong, good brakes and cheap... perhaps retrofit series II, Mazda RX 7 ? roverman.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: June 02, 2011 07:07PM
The SD1 struts are taller, have a larger diameter tube, larger spindles, bearings, hubs, and brakes. I started by cutting off the spring perch. Then using a pipe cutter, a section of tube was cut out. I can't remember how much, but it was enough to make the tubes the same length as the TR8 ones. I butt welded them back together and ground the weld smooth, making sure to do the cutting and the welding on the part of the tube that was getting the new spring perch. I went with adjustable coil overs, so the new perch was a piece of pipe wrapped around the tube and welded in place over the cut/repair. Five inch threaded collars and adjustable perches were slid down the tube so that they sat on the pipe of pipe. The hubs were taken to a machine shop where the lug holes were filled and redrilled to 5X4.5 to match the ford rear end. The TR8 steering arm, lower control arm and ball joint are a direct bolt on. Once installed, you will end up with a little negative camber, that can be taken out by slotting the towers or with camber plates if you so choose. I left it the way it is. A little negative camber is a good thing. I didn't stop there, the brakes are Willwood calipers with modified 284mm vented Jeep rotors and the inserts are adjustable Konis.
bsa_m21
Martin Rothman
Vancouver, Canada
(216 posts)
01/06/2009 11:41AM
Posted by: bsa_m21
Date: June 03, 2011 03:21PM
Thanks Todd,
Exactly the info I was looking for!
M.
KBStag
keith bohanan
(13 posts)
08/31/2011 10:10AM
Posted by: KBStag
Date: August 31, 2011 10:36AM
Nice work. Looks like a fun car.
