Re: 1973 Triumph Stag with 3.5L Rover all-aluminum V8
Hi Jim,
Can't help you with the Fuel Injection question, but if you don't get some input, post in the Engine board. More traffic on that sort of question there. Let folks know whether you got the ECU, engine harness, etc. from the donor or if you're trying to use some sort of after market FI controller. |
Welcome fellow Texan!
Looks like you have a solid foundation for a sweet ride. There are two basic types of EFI systems fitted to the Rover V8s. Both systems respond to information from sensors relating to motor temperature, throttle position, air temperature and engine speed...but neither has any control over ignition. The first system, uses the Bosch air-flow meter with a Lucas analogue ECU. This airflow meter has a hinged flap that the air/fuel mixture can be altered by turning the CO2 screw on the air flow meter and accurate adjustment requires an exhaust gas analyzer. The second system, found in the Range Rover/Discovery only, was introduced to coincide with the "new" 3.9 litre engine in 1988 but was also fitted to some 3.5 litre engines. It incorporates an "hot" wire air metering system designed and manufactured by Hitachi and is matched with a digital Lucas ECU with its fueling information stored on a computer chip/Eprom. This system contains no moving parts and employs two sensor wires, one of which is heated, to measure the air mass as it passes over the wires and into the engine. A voltage signal is then sent to the ECU reflecting the voltage required to maintain the temperature of the heated wire as it is cooled by the air flow. The earlier type was also fitted to the first 3.5 EFI (not catalytic converter equipped) Range Rovers from 1986, is similar (though not identical) to the system fitted to the SD1 Vitesse, the main difference being the ECU (electronic control unit). The hotwire type, fitted to the later Range Rover 3.5, 3.9 & 4.2 vehicles, with or without cat's, despite appearing quite similar, shares few parts with the "flapper". One needs a digital computer to diagnose a digital computer (ECU) and software and knowledge to TUNE it, thus I like carbs! |
donkelly23 Don Kelly Charleston, SC (130 posts) Registered: 07/21/2011 05:13PM Main British Car: 1980 TR7 V8 Z28 FI ECM 4.0 |
Todd, OLD SCHOOL
Jim, I am using,on my 4.0, the FI out of a ODB1 GM, (Z28,Corvette) Basically map sensor, IAC,TPS,and IAT. It's tuned by a company in MI. Also if your smart, you can "squirt" it Don |
