Triumph Sports Cars
Icekottarinn
S. Markus Johannsson
Reykjavik, Iceland
(35 posts)
07/17/2011 07:47PM
Triumph Spitfire Mark III 1968 1300
Rear axle - air breathing?
Posted by: Icekottarinn
Date: December 24, 2011 06:42AM
Can anyone inform me if there is a "air breathing" on the Rear Axle (rear diff) in Spitfire Mk3?
If so (as I hope) where is it ? :)
It has a leak problem in my car and I just wanted to make sure it was "breathing"
- is there a common leak problem for this diff/rear axle? If so any good advices appreciated.
Thanks
Edited 1 time(s). Last edit at 12/24/2011 06:44AM by Icekottarinn.
Icekottarinn
Reykjavik, Iceland
(35 posts)
07/17/2011 07:47PM
Re: Rear axle - air breathing?
Date: December 26, 2011 09:34AM
Anyone?
Does this rear axle have a "breathing"?
BWA
(344 posts)
04/13/2010 08:13PM
Posted by: BWA
Date: December 26, 2011 10:56AM
On my TR6 differential there is a small cotter pin that fits loosely in a hole for breathing. Look for something similar on the top of your differential. You will most likely find it on the back half of the differential that is made out of cast aluminum.
Byron
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Posted by: Bill Young
Date: December 26, 2011 10:59AM
We've seen your post. I personally don't know, no sign of a vent in the manuals but I would think that it should have a vent to prevent lubricant blowing out the seals. I'll check with a friend of mine who has a Spitfire and let you know,might take a day or two though.
Icekottarinn
Reykjavik, Iceland
(35 posts)
07/17/2011 07:47PM
Date: December 30, 2011 08:24PM
Thank you Byron, I did check this out, but it is not easy to see without removing the diff from its place. I will try again tomorrow when in the garage.
And thank you Bill for replying, I would appreciate the answer from your friend.
