Re: TVR and TR6 (?) NIssan based hub and axle mods
What would you charge for a set of the adapters?
I have been looking at the same thing, even have a set of Nissan hubs. Plus I have a set of Mazda 3 rear brakes that have the E brake built in Edited 1 time(s). Last edit at 02/17/2016 10:17PM by v869tr6. |
ALV Al Vandergoot Sidney, British Columbia Canada (67 posts) Registered: 01/13/2013 09:49PM Main British Car: 1971 Triumph TR6 Ford 2.3 turbo |
yeah i would be intereste as well in the hub adapters for the TR6.. i have the good parts diff mounting kit and q45 diff ready to go but also have the complete q45 drive axles out of the differential donor car. the hub adapter was holding me back from using it. Shame for them to go to waste.
btw the four bolt 240sx hubs were from 89-94 after that 5 bolt. Edited 1 time(s). Last edit at 02/24/2016 08:03PM by ALV. |
Looks like the VW T2 axles would be too skinny to re-spline for the Nissan stuff. So starting with the Nissan axles might be a better bet. Nissan has the input of the R200 centered so the axles are different lengths left to right with the right side being the longer of the two. "Rebuilt" they're $85-130, or like I said around $60 for a pair from a yard. I would want to know from someone how well the outer Q45 CV fits inside the TR6 hub carrier. It's a little tight on the TVR.
