Triumph Sports Cars
Goto Thread: PreviousNext
Goto: Forum ListMessage ListNew TopicLog In
dwtr6v8
Don Watson
West Virginia
(169 posts)
12/07/2007 07:45AM
1974 TR6 Ford 5.0 HO
TR6 Rear Disc Brake Brackets, CAD files for the taking
Posted by: dwtr6v8
Date: February 04, 2008 07:27AM
I have the CAD files that I used in making the TR6 rear disc brake brackets.
I have various file formats so if you can locate a CNC Shop, I think they will be able to turn you out a set of brackets. (ASC, DES, Dra,DWG,DXF, WRL,STL, IGS, STP,VDA, even a jpeg for reference)
This jpeg attached is without information just to give you the idea of quality.
These are free for the asking and an email account that can take some large files.
Disclaimer
These references, resources, the materials and products on this site are provided "as is" and without warranties of any kind, whether express or implied. To the fullest extent permissible pursuant to applicable law, this automotive brake modification is undertaken at your own risk and disclaims all warranties, express or implied, including, but not limited to, implied warranties of merchantability and fitness for a particular purpose and non-infringement. The provider does not represent or warrant that the functions contained in these resources will be uninterrupted or error-free, that the defects will be corrected, or that this site or the server that makes the site available are free of viruses or other harmful components. The provider does not make any warrantees or representations regarding the use of the materials in this site in terms of their correctness, accuracy, adequacy, usefulness, timeliness, reliability or otherwise.
By purchasing this custom rear brake conversion or undertaking your own modifications based on these materials as reference, the provider shall not be liable for any special or consequential damages that result from the use of, or the inability to use, the materials on this site or the performance of the products.
74ls1tr6
Calvin Grannis
Elk Grove,CA
(659 posts)
11/10/2007 10:05AM
74 TR 6 2002 5.7 LS1 Chevy
Re: TR6 Rear Disc Brake Brackets, CAD files for the taking
Posted by: 74ls1tr6
Date: February 04, 2008 10:31AM
Hi Don,
Send them to my email or do I have them on the cd you sent?
Thanks,
Calvin
tycorace
mark thompson
(45 posts)
05/31/2008 02:00AM
Posted by: tycorace
Date: June 01, 2008 06:14PM
Insted of making a brake adapter for the
z set up 8us the intire raer end , breake system for a supra it almost fits with out mod look at t
mark
dwtr6v8
Don Watson
West Virginia
(169 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: June 03, 2008 12:13PM
Mark,
Thanks for the lead on the Supra.
One reason for the brackets, as opposed to a full rear system swap, was to reduce the level of fabrication needed to make the conversion from drums.
I agree that a complete system would be best. Most of those looking at this option will modify the frame to accept a Ford 9" and convert to rear disc brakes.
I few concerns, but ones that could be overcome: (photos from my friend, Jeff T.)
1) the TR6 frame does not lend it's self of a complete sub assembly, like the Supra, Jag, Ford Explorer, etc.
2) The Supra runs a 2 piece drive shaft and the flange attachment is not a U-Joint , but a flex plate. Not that this is bad but a drive shaft system would need to built or the flange plate on the differential would need to be fabricated to mate the TR6 drive shaft.
3) The front and rear mounts look like a mounting plate could be fabricated just like the Richard Good Parts kit for the Nissan differential kit , but the upper and lower control arms would need to be modified or replaced with a narrower stance to fit the TR6 width.
Please share with the group more info on the Supra rear system as we are always looking for options on modification for our rides.
4) Price? Each region has different rate and resources, but in my region of the States the complete Supra rear system is rare and running about $1800, if they are found. $800-900 for just the differential.(USED, not rebuilt) I must keep in mind that IRS system are not cheap, but trying to keep to a budget does impact our directions.
Any resources you can share?
kmcphee
Kevin McPhee
(1 posts)
06/06/2008 01:13PM
Posted by: kmcphee
Date: June 06, 2008 01:39PM
Hi, could you send me the file in a jpeg format. Thanks, Kevin (kcmcphee@eastlink.ca
dwtr6v8
Don Watson
West Virginia
(169 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: September 25, 2008 07:14AM
More are being made!
I'm posting this with his permission.
A gent in Canada is getting ready to make a run of about ten sets!
A fellow TR6 has requested he turn out a set of brackets.
Francois has offered to make about 10 sets.
So, If you are interested, here is his contact information:
François Faucher
fr.faucher@videotron.ca
[hotantiqueauto.googlepages.com]
Check out his TR6 mods. I love the shroud cover.......that's HOT!
dwtr6v8
Don Watson
West Virginia
(169 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: February 06, 2009 07:46PM
A Custom Auto Shop in Texas has made another run on the rear disc brake brackets.
The picts also show Richard Goods CV Joints installed with the brackets and coil overs.
Please contact them directly if you are interested.
Ron Harrison
ron@rvar.net
713-857-7733
dwtr6v8
Don Watson
West Virginia
(169 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: February 06, 2009 07:48PM
Colorado USA
(2199 posts)
Date: February 06, 2009 10:13PM
What great pictures! (I especially like your wheels and tires;)
You're going to write an article about this whole set-up, aren't you?
74ls1tr6
Calvin Grannis
Elk Grove,CA
(659 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: February 06, 2009 10:53PM
In some of the photos show a stock frame being used and other photos show a Ratco frame being used. The sway bar I believe is from Revington TR UK.
Maybe between Don and I, we can write the article that should be done with this setup. I did take notes on how mine were done. I think Don should take all the credit for the article as for he drew up the cad files for the brake brackets.
I'm getting a quote on 10 sets of these brackets to be made shortly (with Don's files). When I get the quote back I will post here in this section of the price. The price will be what I paid for them + shipping to .... Just helping out the Triumph owners.
crj7driver
Ryan Deal
Colorado
(15 posts)
02/27/2008 10:59PM
1970 TR6 Toyota 1JZ-GTE 2.5L
Posted by: crj7driver
Date: February 09, 2009 11:47AM
With regards to the Supra rear end. I am running one in my project along with custom CV axles. It is narrower than the TR pumpkin or Nissan, but it will require axles that are unequal in length. Also, my diff has a 4 bolt flange that bolts up to the drive shaft. It is out of a 91 Turbo supra LSD. The mounts were custom fabricated by me and not too difficult. I would have gone the Nissan route but I already had this differential sitting around.
http://i31.photobucket.com/albums/c374/crj7driver/DSCN2555.jpg
I have a few more pictures I just need to find them
dwtr6v8
Don Watson
West Virginia
(169 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: February 21, 2009 09:41AM
Sure CJ,
I know that Calvin and I can share a lot of lessons learned and by others that have taken on this type of modification.
So Calvin, look for the first draft coming you way. Just what you need while your building your TR6-LT1, fixing up the Spit with your son, producing brake brackets, (see below comment) and keeping me out of trouble!
Ryan,
Nice work on the differential swap! Looks robust! Please send us more pics and specs on the mounts and "How 2s" What did you design for the front mounts?
I know that others are looking for replacement/ performance options!
Plus our friend and fellow British/American motor-head is working on another production run of the TR6 Rear Disc Brake Brackets! Not for money, but for the SPORT! Not as a business, but as a help to others! (he already has a set on his TR6) The cost to CNC one set is too much for most people, but with quantity, the cost drops to with in reason.
If you would like to motor down this modification road, please contact Calvin directly.
Sent a private message thru BV8 right here or his email waterhook@surewest.net
Here is a shot of what got the thinking process going. I friend had a Nissan 240Z that he converted to rear disc with a kit. The swing arm desing is not that different. OK, different enough that it did not fit, but started the brain cells talking to each other.
More to come from "CalvinDon Publications"
74ls1tr6
Calvin Grannis
Elk Grove,CA
(659 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: March 13, 2009 10:22AM
OK...The run of TR6 brake brackets has started. They should be done in a couple of weeks. I don't think the rules here let me post the price or sell something here in this section.
E-mail if you have interest or PM me. My E-mail has been posted above.
I have 10 sets being made at this time, and can do another run later if more people want them.
Calvin
Note* If you order Richard Good's CV axles and use these Brake Brackets, "TELL" Richard about the 1/2" brake bracket going between the trailing arm and the hub. He will compensate the difference there for the axles. I thought of this after I ordered them and called him, I believe Albert Waynburg (SP) did the same after talking with him a few days ago.
Edited 2 time(s). Last edit at 04/02/2009 12:28AM by 74ls1tr6.
74ls1tr6
Calvin Grannis
Elk Grove,CA
(659 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: August 07, 2009 10:26AM
I have put in an order for a run of 10 more sets of disk brake brackets yesterday!
This coming Monday, the machine shop will let me know of a completion date.
There have been 4 inquiries for these disk brake brackets to be made, so there will be 6 to 7 set’s available at this time of post left of the run. 8/7/2009 (today)
Same price of:... Look here for price at the bottom of page...[forum.britishv8.org] shipped in the US and more postage out of US.
For inquiries for the brackets, email waterhook@surewest.net
Calvin
74ls1tr6
Calvin Grannis
Elk Grove,CA
(659 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: August 31, 2009 03:12PM
Update!
The machine shop let me know the brackets are being plasma burned now!
There are 7 sets out of the 10 spoken for already, and 1 inquiry as of today!
Also had an inquiry to have these brackets made in aluminum 1/2" thick (for unsprung weight). I'm getting a quote for 1/4" thick steel brackets too. The only difference using 1/4" steel brackets, would be 1/4' shorter trailing arm studs, and 1/4" shorter caliper mounting bolts. A caliper bracket made in 1/4" steel is plenty strong; they use 1/4" for off road racing.
Calvin
Edited 1 time(s). Last edit at 08/31/2009 03:20PM by 74ls1tr6.
74ls1tr6
Calvin Grannis
Elk Grove,CA
(659 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: September 06, 2009 11:11AM
Update!
I will picking up the run of disk brake brackets today!
Will be painting them within the next couple of days + drying time.
There is some left up for grabs from this run still.
Got some pricing on 1/4" steel brackets and 1/2" aluminum brackets. Finding out if the machine shop is setup for the run, it's easier to get the 1/4" steel and 1/2" aluminum ones made and not have a full 20 pieces made.
Will post pricing in classified section.
Calvin
