Triumph Sports Cars
Goto Page: Previous12
Current Page: 2 of 2
dwtr6v8
Don Watson
West Virginia
(267 posts)
12/07/2007 07:45AM
1974 TR6 Ford 5.0 HO
Re: TR6 Rear Disc Brake Brackets, CAD files for the taking
Posted by: dwtr6v8
Date: February 14, 2018 08:36AM
A very nice conversion with a different take on the e-brake setup, take a look.
Good work Kelly!
Regarding E-brake, I used new stock TR6 cables from Moss; I machined a trunnion to thread onto the end of each cable and fit in the caliper ‘saddle’ to pull the e-brake mechanism. I used a 3/8” AN bolt - the unthreaded shank area. I think it is 4130 steel. Very strong. Drilled it with cobalt drill and tapped 1/4-28. I fabricated the brackets that attach the cable to the caliper from 1/4” x 1” cold rolled steel. Works perfectly. No modification to the cable necessary. Brake handle pulls up 4 - 6 notches for solid grab. Easy to adjust at caliper end as pads wear.
Also, I machined the caliper mounting brackets from 7071-T6 aluminum 3/8” thick. The alloy is much stronger per square inch than mild steel of the same thickness. Of course I upgraded the swing arm studs to 3/8”.
Here are some pix of the e-brake set up and my engine / cockpit. And yes, I know, I need to get the airbox I fabricated polished!
Thank you once again.
Cheers, Kelly
ALV
Al Vandergoot
Sidney, British Columbia Canada
(61 posts)
01/13/2013 09:49PM
1971 Triumph TR6 Ford 2.3 turbo
Posted by: ALV
Date: September 23, 2018 12:34PM
Hello would it be possible to send me a jpeg of the file please. Thanks.
dwtr6v8
Don Watson
West Virginia
(267 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: September 24, 2018 08:00AM
ALV, please send me an email address and I'll send you all the files. Too many to attach here.
ALV
Al Vandergoot
(61 posts)
01/13/2013 09:49PM
Posted by: ALV
Date: September 24, 2018 08:58PM
Great many thanks Don.
Slicker
Timothy Mantel
(1 posts)
11/08/2018 03:51PM
Posted by: Slicker
Date: November 09, 2018 05:11PM
Hello TR fans, I have read your article, regarding the rear disc brake conversion, and would like to try this on my TVR 2500M. If there is an outlet for these brackets, could you please steer me in that direction. If that information is not available, please reply how I may receive the Cad file, or detailed sketch, so that they may be re- produced. Thank You, Tim
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1145 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: November 09, 2018 08:16PM
send me your email address and I will send them to you ....personal message me.
ALV
Al Vandergoot
(61 posts)
01/13/2013 09:49PM
Posted by: ALV
Date: November 22, 2018 11:14AM
Hello all a bit of an update here. Got brackets machined and all not an issue but i did have an issue trying to source calipers, in particular the driver side caliper is apparently a rare bird. Cardone, rock auto etc are all out. I finally got one from stockwise auto. Also as the article states there was a change in disc calipers styles for the maxima mid 1987, i had the best luck searching using 1986 as the model year. If you do get a hit for a rear caliper and it is made by Beck/ Arnley i would take a pass as the caliper mounting brackets dont fit properly in the machined bracket. Cheers everyone and happy thanks giving to our friends in the USA.
BrianPahl
Brian Pahl
(2 posts)
05/03/2019 07:57PM
Posted by: BrianPahl
Date: May 03, 2019 08:59PM
Got them, Thanks Don!
Edited 1 time(s). Last edit at 05/04/2019 12:33PM by BrianPahl.
BrianPahl
Brian Pahl
(2 posts)
05/03/2019 07:57PM
Date: May 03, 2019 09:07PM
Sorry dupe post, things keep timing out here :)
Edited 1 time(s). Last edit at 05/03/2019 09:09PM by BrianPahl.
dwtr6v8
Don Watson
West Virginia
(267 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: May 04, 2019 08:30AM
Brian, I sent you the CAD files.
Enjoy the Journey!
gmcswiggan@yahoo.co.uk
George McSwiggan
(1 posts)
06/03/2019 11:46PM
Posted by: gmcswiggan@yahoo.co.uk
Date: June 03, 2019 11:54PM
Hi Don,
Any chance you would be good enough to send through the CAD files for the brake brackets to gmcswiggan@yahoo.co.uk ?
Many thanks in advance
dwtr6v8
Don Watson
West Virginia
(267 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: June 04, 2019 09:00AM
I sent to your email address, different CAD file formats depending on what CNC shop needs.
