Triumph Sports Cars
New to the Gallery: Don Childs' TR6 V8!
Date: July 19, 2017 04:27AM
Please join me in congratulating Don on a job well done!
Read Don's How-It-Was-Done Article Here
http://www.britishv8.org/Triumph/DonChilds/DonChilds-AA.jpg
Re: New to the Gallery: Don Childs' TR6 V8!
Date: July 19, 2017 10:01AM
Looks good Don.
(4514 posts)
Date: July 19, 2017 10:59AM
Sweet!
Dan B
Dan Blackwood
South Charleston, WV
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: July 19, 2017 02:55PM
Nice!
How many meanings intended in the vanity plate?
Edited 1 time(s). Last edit at 07/19/2017 02:56PM by Dan B.
(2463 posts)
Date: July 20, 2017 04:36PM
Very Nice!!
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: July 23, 2017 12:08AM
Nice Ride Don, thanks for adding to the TR6 section :)
dwtr6v8
Don Watson
West Virginia
(305 posts)
12/07/2007 07:45AM
1974 TR6 Ford 5.0 HO
Posted by: dwtr6v8
Date: July 26, 2017 04:12PM
Great Job and even better color! Congrats!
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
1972 TR6 1994 5.7 L GM LT1
Posted by: TR6-6SPD
Date: July 27, 2017 07:57AM
Nice wheel choice.
dchilds
Don Childs
Cass City, Michigan
(9 posts)
09/03/2009 11:17PM
1976 TR6 Ford 302
Posted by: dchilds
Date: August 03, 2017 10:09AM
Thanks to all for the compliments.....Have a little over a 1000 miles on it now..........it's a blast........people think its a Cobra...."What kind of kit is that?" "Is that original?" makes my day..................Taken it to a couple of car shows & watch people scratch there head as they walk around it.......Performance is awesome...had to upgrade to Drag radials to keep from spinning (Nitto NT555R 275/40-17).....hooks hard......unofficial times: 0-60 4.2 seconds......1/8 mile 8.5 @ 92 mph.....still tuning.........
tork
Michael Clark
Gilroy, CA
(10 posts)
07/08/2017 02:04AM
1967 TR4A Ford 302 w/AOD
Posted by: tork
Date: August 11, 2017 08:57AM
Very nice,
But a couple of questions.
I see you have a T5 transmission.
From the gearset you stated with the 3.97 first gear. Is this the transmission for Ford 2.3's rated at 240 ft Ibs?
1) How has it held up? You have some very fast times posted and you have a lot of tire stickiness.
2) Are you using a shifter relocator? From the pictures of the cockpit the shifter appears to be a nice forward location, but the off body chassis picture shows the shifter location back kind of far. If you are using a shifter relocator which one are you using? And how do you like it?
I am thinking about a T5Z with a 302, warmed over a bit. And I am only going to run 205/70's. I want to hear from folks about their shifter relocation brands and their success with the shifters. I thought about a TKO as it has multiple locations, but money, weight, and other issues mean I am trying to avoid it. My engine will never overpower the TKO, but with the T5Z I will be over the rated torque. But I am not going to be banging thru the gears very often.
regards,
Tork
IaTR6
Dennis Costello
Central Iowa
(192 posts)
12/29/2007 02:53PM
'73 TR 6 '97 Explorer 5.0
Posted by: IaTR6
Date: August 11, 2017 11:52AM
Tork, I used a '97 Ford Explorer engine as the basis for my build specifically for the short front engine dress. The water pump, timing cover and front damper/pulley are the shortest Ford used on the Windsor 5.0. I spaced my crank pulley just 1/2" behind the steering rack, and with a standard T5 Mustang unit and a straight shifter, I am right where the old shift ball was. The original Triumph shifter base was closer to the firewall, but has a 5" bend (memory here, was it 5 or 3??). Take a look at the pictures in my project journal under Dennis' TR6.
I suspect since you seem to have your engine already installed - is that correct? Then you would have to use that as a start. Options are S-10, rare Astro van or custom tailshaft housings. Or the TKO, which was over my budget.
As to the 240 ft lb limit of the 4 cyl trans, it may be that it would live behind the V8 if you don't abuse it, but since you are going to the trouble, I would suggest a
T5 at least upgraded to the 300# rating.
One last comment, is that I have a 3.35 1st gear, a 3.54 R200, with 205X65-15 tires, and think my low gear is maybe a little too low. Starting in 2nd is pretty easy (hey, I drive an automatic most of the time!), and the 2.95 of the T5Z might be nice. I think I get 10 mph in 1st @ 1600 rpm, which gives ~ 37 mph a@ 6000. That's ok for a drag car I guess, but for me, I would like a little longer run before shifting. I have NO intention of ever doing a drop the clutch start, stop light drags are 20-25 and punch it for me!
Dennis
tork
Michael Clark
Gilroy, CA
(10 posts)
07/08/2017 02:04AM
Posted by: tork
Date: August 12, 2017 11:25AM
Dennis,
I found your posting in the Project Journal section. So I added/will add my questions there in the parallel thread.
My question here was to Don's use of the T5 with the 3.97 first gear. If it is holding up for him, then a T5Z will work for me. His power and tires are well above what I have or plan.
Right now I have a 302 with an AOD. Since I drive all automatics, I want a manual.
dchilds
Don Childs
Cass City, Michigan
(9 posts)
09/03/2009 11:17PM
1976 TR6 Ford 302
Posted by: dchilds
Date: August 14, 2017 09:03AM
Tork:
Transmission is a T5 from a 5.0 Mustang.....may have gear ratios wrong
Engine/ Transmission are in same position in all pictures
No shifter relocation needed.
As to times:
Not official...done with stopwatch & apps.
About 350HP @ Crank...Shifting @ 6K RPM
These cars are very light and do not stress the driveline much.
Quick times are the result of a very stiff chassis, good tires & the rear suspension having the correct anti-squat geometry.
Here's the link to my project journal.
[forum.britishv8.org]
