spridget bill green Maine (69 posts) Registered: 03/22/2008 01:29PM Main British Car: 3 1980 TR8, 1 TR7 2 Bugeye Sprite 1 MG midget TR8 3.5 and 5.0, Sprite 1098 and ? |
TR transmissions
Is there any difference in the shift linkage, shifter location between TR7 and TR8 transmissions?
Re: TR transmissions
The TR8 shifter quadrant is slightly shorter than the TR7. Its only about 3/8" but its enough that if you use a TR7 quadrant behind a Rover V8, the back section of the tunnel opening will need a little cutting. FWIW, the quadrant for a Rover SD1 is identical to the TR7. The transmission mounting brackets are also slightly different. Whereas the the TR7 bracket is essentially straight across the TR8 bracket has a swept wing appearance to it. When they were new, the TR7 mount was softer than the TR8, but now they are all the same. The MGB V8 guys cut and weld the quadrant and shift linkage to make them shorter, but I don't know how much they remove.
If you look about 3/4 of the way down this page, there are pictures of how the TR7 shifter can be shortened. FYI - The standard TR8 shifter was about 3/4" shorter than the TR7 version, not the slightly more extreme 2" shortening that Mike did for his race car.
[forum.britishv8.org] M. Edited 1 time(s). Last edit at 09/18/2017 03:15PM by bsa_m21. |
