Nearing Completion of My TR6
Re: Nearing Completion of My TR6
Hello and welcome.
Quite a shoehorn job under the bonnet. Even found room for the battery! Extensive rework under the skin, but the bodywork looking stock, incl the bumpers, I like that. Normally I don't like low-profile tyres on the TR6, but with the (unusual) silver paint it seems to work for me. How does the ride/suspension performance compare to stock? Ivor Edited 1 time(s). Last edit at 03/30/2020 04:24AM by 88v8. |
Dave welcome to the forum.
You have done a real nice job. You have done a "Chip Foose" thing on your car and if you did not show those photos of the work in process it would have been hard to tell what was done. Please post more photos of the car from other angles so we can see your workmanship. Cheers Byron |
Looks great Dave. Like others, I'd love to see more pics. Do you have a build thread somewhere?
Nicely done Dave. You should consider doing a project journal on this site. There is plenty of space available for both text and photos.
Great info, thanks for sharing it. Especially the spreadsheet info.
Very Nice!! Lots of creativity and great craftsmanship. Enjoy driving it!
Dave,
First of all, WOW! What a fantastic job you have done. Very much what I intend to do, or have wanted to do for some time now. The body work is supreme. Looks as if it is factory. Just brilliant! I have several questions about your build and am hoping you might be willing to give some advice. I would guess you might be an engineer or a custom car builder like the guy from Texas Metal with these skills, but regardless you have been there, done that and can really help those looking to do something similar. So here are a few questions. 1) The frame looks amazing. Did you design and build it? 2) What size wheels and tires are on it? 3) From one of your posts, am I to understand you didn’t really alter the front of the car (maybe with exception to the fender flares), but the rear wings were cut along the joint line going from zero at the door jam and widening1.75” at the back? 4) How much flare was added to the fenders (wings) at the wheel well? Thank you for sharing your build with us and being an inspiration to me. Regards, Anthony Medina BLOKEMOTO |
Caramba, that's almost a new car. Over here in the UK, the licensing people would have a hissy fit and make you jump through all sorts of hoops before you could put it on the road.
Looks as if you managed to use the standard screen. However, I guess among the smaller jobs was a custom soft top and widening of the folding frame. A really remarkable job. Ivor |
Dave, thank you very much for your post and the photos, very informative and illustrative.
Part of my prior confusion stemmed from the notion that the engine should be positioned such that the block is entirely behind the front cross-member. I have realized (with your help) that this is impractical and not necessary. Also, I noticed that the original inline six-cylinder engine sits partially over top of that cross-member as well. May I ask a few more questions: - What is the pulley spacing of your frontend accessory drive? Is it the tight spacing used in the Corvette? - Would you be able to post a photo of the front of the engine, showing accessory locations and belt routing? I have not seen the alternator placed high on the passenger side before, it looks very well done. - Did you have to modify the inner fenders at all to clear the alternator/AC pump/PS pump? - What are the motor mounts that you used? Thanks again. |
Thank you Dave, appreciate the photos.
There is an AC compressor listed in your table of major components (along with a Vintage Air system). Your pictures don't seem to show an AC compressor. Did you end up deciding against AC? Edited 1 time(s). Last edit at 05/09/2024 04:55PM by Bremer. |
