Triumph Sports Cars
tbush
Tim Bush
Minnesota, USA
(32 posts)
11/16/2009 07:29PM
'74 Spitfire, '59 Frogeye (sold) GM Vin T 3.1Lgoing in it.
V6 spit in progress
Posted by: tbush
Date: July 01, 2010 10:10AM
I have been working on a spitfire restoration and conversion. Here are a few pics.
This is the frame with the new mounts for a 3.1L V6. They bolt into the original locations.
http://farm5.static.flickr.com/4100/4750230072_216671b890.jpg
The frame has been stripped, notched, reinforced, painted, and coated with urethane undercoating.
Engine in place. The oil pan has been modified to straddle the steering rack.
http://farm5.static.flickr.com/4074/4749800593_2cc119d438.jpg
The steering rack is in the original location. The timing cover, water pump, pulleys, and oil pan are from a Fiero VIN9 2.8L.
Driver side mount. Gear reduction starter. T5.
http://farm5.static.flickr.com/4074/4750444326_b9ea91a284.jpg
View from the rear.
http://farm5.static.flickr.com/4138/4749801517_90e883b05d.jpg
- Tim
Dan B
Dan Blackwood
South Charleston, WV
(1007 posts)
11/06/2007 01:55PM
Re: V6 spit in progress
Posted by: Dan B
Date: July 01, 2010 10:33AM
Nice work!!
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Posted by: Bill Young
Date: July 01, 2010 03:17PM
X2 Very nice workmanship on that installation. Can't wait to see the body on and see how it all clears the hood etc. Looks like it was designed from the start to have a V6.
tbush
Tim Bush
Minnesota, USA
(32 posts)
11/16/2009 07:29PM
Posted by: tbush
Date: July 01, 2010 09:35PM
Bill,
After many measurements and tweeks I determined the clearance to the bonnet will be damn close. I am willing to put a bulge in the hood, but not a hole.
Plan B is to swap the top end with SFI parts. I got a sweet deal on a remanufactured long block with brand new heads. I hated the thought of tearing them off and finding rebuilt SFI heads. I figure I will try this first and see. Manifolds are cheap.
Firewall clearance should be good.
I will be putting a remote oil filter on the car. The stock location has an interferance with the shock tower.
-Tim
s1b
Sean Bittle
(5 posts)
09/27/2010 11:24PM
Posted by: s1b
Date: October 10, 2010 08:35AM
Anymore progress on this one?
tbush
Tim Bush
Minnesota, USA
(32 posts)
11/16/2009 07:29PM
Posted by: tbush
Date: October 14, 2010 08:38PM
Progress has been slow. Work and Summer stuff getting in the way.
The body trial fits have gone good. No firewall changes are required. The shifter location will be close to the stock location when I finish a custom lever.The body restoration work is almost done and ready for paint. Painting will have to wait as it is too cold now. Picked up some nice Miata seats a few weks ago. Right now I am working on splicing a Cavalier IP in to the dash.
-Tim
switchb atch
Mark Redman
Vancouver, Washington
(8 posts)
11/03/2010 04:43PM
1969 Triumph Spitfire No engine........Soon to be 3.4L fuelie
Posted by: switchb atch
Date: November 06, 2010 04:22PM
Tim,
I am in the process of installing a 2.8L with a T5 from a 86 Camaro. I'm curious as to what clutch slave cylinder you are using. I will have to delete my pusher type because it is interfering with the frame and install a puller or do the hydraulic throwout bearing.
tbush
Tim Bush
Minnesota, USA
(32 posts)
11/16/2009 07:29PM
Posted by: tbush
Date: November 20, 2010 12:17PM
Mark, I am using a iron slave cylinder from a 80's vintage S10. I have a S10 fork, piviot stud, and throwout bearing.
I also am using a S10 bell housing. This bell housing has the slave cylinder at a 90 degree angle to the engine. The Camaro/Firebird bell housing has the slave at a 100 or 105 degree angle as I recall.
The slave cylinder clears well and fits under the transmision cover without modifications. The only thing I did was bend the "flange" of the frame down a bit for additional running clearance.
A S10 bell housing should fit your engine and transmission just fine. Your shifter will also be straight up and down and not angled like on the Camaro/Firebird.
- Tim
switchb atch
Mark Redman
(8 posts)
11/03/2010 04:43PM
Date: November 25, 2010 06:44AM
Tim,
Thanks for clearing that up for me. I suppose I will have to purchase another transmission for all of the parts I will need. I like the idea of having the shifter more forward and upright and being able to have access to the slave cylinder if needed. I will rebuild the trans I have so while it is apart I will change the tail shaft and the bell housing. Your motor mounts are interesting. My plan is to use the OEM type and weld them to the uprights while modifying the engine side plates for the necessary clearance.
Very nice project you have going. I hope to have some pictures to upload soon.
switchb atch
Mark Redman
(8 posts)
11/03/2010 04:43PM
Date: April 27, 2011 12:37AM
Tim,
Sent you a pm........it's been awhile since I've had time to do any serious work on my project. I've decided to go with the HTOB on mine and just cut the bell housing since I'm changing from MPFI to carb and rebuilding the engine and trans before installing. I'm doing a custom trans mount of course and hoping I can use as much of the plastic trans tunnel that I can. More on that after the drivetrain is installed and the interior is being put back.
spitfire79
wes brown
Schertz, TX
(15 posts)
10/11/2008 03:54PM
spitfire 80 chevy v6 2.8 looking to place in
Posted by: spitfire79
Date: December 25, 2011 10:49PM
i am very interested in your project and would like as well to install as well, some questins
were there any mod to the frame, for the transmission.?
motor mounts 3.1L V6, were from what?
oil pan modified to straddle the steering rack, any pics and or measurements?
timing cover, water pump, pulleys, and oil pan were from a Fiero VIN9 2.8L, what year,?
by chance do you have any more pics you can share
i can be reach at wjb_217@yahoo.com
thank you
scot abbott
scot abbott
(26 posts)
01/30/2008 06:03PM
Posted by: scot abbott
Date: January 29, 2012 11:20PM
I'm keen to see this unfold. I've built a few GT6 spitfires and use the GT6 bonnets because they have a bulge in the center and look very nice in place. I've done a number of mgbv6's and use the s10 bell housings and camaro T5 tranny because it fits nicely into the narrow confines of the mgb tunnel. You just have to remember to use the s10 flywheel, too.
rampant racing
gary fraser
sarnia ont,canada
(83 posts)
03/28/2009 02:45AM
69 spitfiremk111 ford 347 stroker
Posted by: rampant racing
Date: January 30, 2012 09:59AM
is this project still around...i haven't seen anything from tim since his last post in nov 2010.
scot abbott
scot abbott
(26 posts)
01/30/2008 06:03PM
Date: February 24, 2012 11:12PM
The RWD 60 degree v6 fuel injected ones have 3 kinds of setups:
TBI, Multiport and 3.4 sfi. The heights are quite different:
the TBI: height to top of air cleaner from valve cover = 7 1/2 "
the MPFI height to top of manifold from valve cover = 5 1/2 "
the SFI height to top of manifold from valve cover = 3 1/4"
all the manifolds bolt up and interchange.
but the sfi has to be modified to clear the Dizzy if it's used.
These measurements show that the 6 doesnt need to be thought of as all that tall,
and there is a 4 inch difference in height depending on manifold chosen. The efi setups can be lower than the carbs by quite a bit..
spitfire79
wes brown
Schertz, TX
(15 posts)
10/11/2008 03:54PM
Date: March 03, 2012 10:39PM
how was your oil pan modified, and what motor mounts did you use,
spitfire79
wes brown
Schertz, TX
(15 posts)
10/11/2008 03:54PM
Date: March 17, 2012 04:42PM
hi
question, for your motor mounts did you use 55 chevy motor rubbers, or s10 transmssion mounts, also by chance do you have any diagrams /measurements of your motor mounts. had to go with a 1993 chevy S10 2.8 motor, and T5 transmission. currently looking to convert trottle body injection to carb. want to get away from fuel injection. not sure how to convert but looking. anyway, was going with fiero engine, and found out it had crack block and other problems. found this 93 engine with t5 transmission for 300.00
we've emailed before, interested in your motor mount setup think it may work with this S10 engine, any suggestion. you also mention that you used, fiero water pump, cause it was smaller? would fiero engine parts fit on an S10
spitfire79
wes brown
Schertz, TX
(15 posts)
10/11/2008 03:54PM
Date: March 26, 2012 09:31PM
are you still out there?
