Re: Reinventing my TR6
I want to make a fiberglass front bumper. I need a steel bumper to use as a mold. I have been looking for some time and have not found a cheap one. Rust is no problem since it will be used as a mold only. I would be interested in "renting" one that I would return when I am finished if anyone knows someone that wants to entertain that idea. I need a early one before the rubber blocks were added.
Dale |
Is that front "clip" all in steel?
Would it not make more sense to have glass fibre (the whole lot) front, top and bottom valance and wings? Could still all be built up as one clip. |
Yes it is all steel. The hood will be fiberglass. I wanted a working hood and I thought that if I also wanted a removable front clip going with steel would be more durable. If I were to start over I might rethink that.
dale |
Med72 Art Medrano Austin, Tx (52 posts) Registered: 01/31/2012 09:25PM Main British Car: 1972 Triumph TR6 GM 350 |
Hey Dale:
Good to see that you are getting the beast back on the road. I notice from the photos that you have a 5 bolt wheels as opposed to the standard Triumph 4 bolt pattern. What did you use to convert this? I know the rear end is either a 8" or 9" so that is the Ford 5 bolt pattern but what did you use for the front? Also, I plan to use a Ford 9" but still debating whether or not I will design a new rear sub frame or do something similar to what you did. What do you recommend? |
Capt'n Moorgone Mike Moor Angola,IN (116 posts) Registered: 11/20/2008 07:05PM Main British Car: 1973 MGB 300 Buick |
Looks great Dale!Can't wait to see it in person. Mike
It's looking good Dale.
Missed you in Palestine; are you planning to make it to Omaha next year? |
Better than new.
