StagByTriumph Glenn Merrell Colorado (35 posts) Registered: 10/25/2007 12:11PM Main British Car: 1973 Stag Rover SD1 3.5 w/ 3.9 EFI |
Re: Stag Engines
Bob,
I may be willing to part with my 3.5 EFI Rover complete setup - u-bolt-it-in - engine/computer/headers/mounts/transmission. If your transmission is an J Type OD I may consider a partial swap but that one is probably an A Type from that Early Stag you have ... If you are interested, let me know directly to my email address. Cheers! Glenn Merrell |
Sparrow010 Andrew Gaskin New Zealand (19 posts) Registered: 06/06/2009 08:04PM Main British Car: 1974 Triumph Stag Toyota 1 - UZ - FE Quad cam 4.0 |
Re: Stag Engines
Thanks Glenn
4 years of work but great to have her back on the road. Is almost like a new car. well worth all the effort. K MAC CC Adj units from Aussie [www.k-mac.com.au] |
Re: Stag Engines
I am also working on a 73 Stag with an injected Rover 3.5. I suggest that you stay with an engine with the distributor in the front. The engine compartment is challenging. I recently completed making new motor mounts and am starting to work on some sheetmetal mods to gain needed clearance around the 700R4 transmission. In my case the aluminum V8 is lighter than the Stag cast iron engine but my transmission is heaver which effectively moves the weight distribution toward the rear.
