Triumph Sports Cars
Sparrow010
Andrew Gaskin
New Zealand
(25 posts)
06/06/2009 08:04PM
1974 Triumph Stag Toyota 1 - UZ - FE Quad cam 4.0
4AGE SPITFIRE
Posted by: Sparrow010
Date: October 01, 2010 09:10AM
Has any one done this conversion ?
Am picking up a 4AGE with T50 gear box this week end.
Fitting into into a MK 4 Spitty
Any tips, lessions learned would be appreciated.
Andrew
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Re: 4AGE SPITFIRE
Posted by: 74ls1tr6
Date: October 01, 2010 10:22AM
Hi Andrew,
Ckeck out this build.
[www.britishv8.org]
Bugeyev8
Brian Marshall
San Leandro CA
(32 posts)
12/16/2008 08:53PM
1960 Bugeye, 1974 MGB,Triumph TR8 1.2 115 Hp 1275 in the Bugeye, Nissan Ka24DE in MG
Re: 4AGE SPITFIRE
Posted by: Bugeyev8
Date: January 20, 2011 04:19PM
Fits great I hear, I have a friend with one in a Morris Minor..sweet little engine, I put a 4AGE 20 Valve in a Bugeye fits great too, are you going to run the EFI ??
Sparrow010
Andrew Gaskin
New Zealand
(25 posts)
06/06/2009 08:04PM
Re: 4AGE SPITFIRE
Date: March 08, 2011 02:28AM
Yep going to run the Std EFI set up and induction.
rampant racing
gary fraser
sarnia ont,canada
(83 posts)
03/28/2009 02:45AM
69 spitfiremk111 ford 347 stroker
Re: 4AGE SPITFIRE
Posted by: rampant racing
Date: March 08, 2011 07:31AM
better give yourself a little more room for that tailstock m8 or it will be an issue down the road.looks like a good swap.good work.
moezilla
Eric Moe
(2 posts)
09/01/2009 02:17AM
Re: 4AGE SPITFIRE
Posted by: moezilla
Date: July 05, 2011 07:43PM
Are you able to fit under the stock bonnet and install without mods to the frame / firewall , and just mods to the tranny tunnel? I have seen one installed with everything left alone - trying to find drawings / photos.
Might do this again to a mKii.
Sparrow010
Andrew Gaskin
New Zealand
(25 posts)
06/06/2009 08:04PM
Re: 4AGE SPITFIRE
Date: July 06, 2011 09:27PM
To fit donk with std inlet manifold under bonnet had to skim a bit of meat of the harmonic balancer. Not happy about this but was only way to get it down with steering rack not being moved. will see if this causes any issues down track.
needed to trim chassie for clutch slave cyl and a bit arround rear half of T 50.
have engine sitting as far back as I can with out mod-ing fire wall.
Rear of trans tunnel is now cut to scratch lines in Pic. A new trans cover will have to be made up, gear stick location now a good 3 inchers back from old Triumph one.
Have fitted a short shift kit to the T50 and fitted a shorter lenght gear lever
Radiator mounts have been fabricated
Now for final strip and sand balast of chassie, then the rebuild.
Will keep up dated
random rs
Dan Lynch
(6 posts)
09/06/2012 09:48PM
Re: 4AGE SPITFIRE
Posted by: random rs
Date: September 13, 2012 12:40PM
any update on this?? im heading down this route myself with a 79 mk4 but im using a blacktop 20v 4age from corolla ae111 mated to the t50 box, just wondering about the positioning and design of the mounts.....
