Sparrow010 Andrew Gaskin New Zealand (25 posts) Registered: 06/06/2009 08:04PM Main British Car: 1974 Triumph Stag Toyota 1 - UZ - FE Quad cam 4.0 |
4AGE SPITFIRE
Re: 4AGE SPITFIRE
Bugeyev8 Brian Marshall San Leandro CA (32 posts) Registered: 12/16/2008 08:53PM Main British Car: 1960 Bugeye, 1974 MGB,Triumph TR8 1.2 115 Hp 1275 in the Bugeye, Nissan Ka24DE in MG |
Re: 4AGE SPITFIRE
Fits great I hear, I have a friend with one in a Morris Minor..sweet little engine, I put a 4AGE 20 Valve in a Bugeye fits great too, are you going to run the EFI ??
Re: 4AGE SPITFIRE
Re: 4AGE SPITFIRE
better give yourself a little more room for that tailstock m8 or it will be an issue down the road.looks like a good swap.good work.
Re: 4AGE SPITFIRE
Are you able to fit under the stock bonnet and install without mods to the frame / firewall , and just mods to the tranny tunnel? I have seen one installed with everything left alone - trying to find drawings / photos.
Might do this again to a mKii. |
Re: 4AGE SPITFIRE
To fit donk with std inlet manifold under bonnet had to skim a bit of meat of the harmonic balancer. Not happy about this but was only way to get it down with steering rack not being moved. will see if this causes any issues down track.
needed to trim chassie for clutch slave cyl and a bit arround rear half of T 50. have engine sitting as far back as I can with out mod-ing fire wall. Rear of trans tunnel is now cut to scratch lines in Pic. A new trans cover will have to be made up, gear stick location now a good 3 inchers back from old Triumph one. Have fitted a short shift kit to the T50 and fitted a shorter lenght gear lever Radiator mounts have been fabricated Now for final strip and sand balast of chassie, then the rebuild. Will keep up dated |
Re: 4AGE SPITFIRE
any update on this?? im heading down this route myself with a 79 mk4 but im using a blacktop 20v 4age from corolla ae111 mated to the t50 box, just wondering about the positioning and design of the mounts.....
