Triumph Sports Cars
PaulAsh27
Paul Ashwood
(1 posts)
10/05/2010 04:07PM
Heater valve for TR7
Posted by: PaulAsh27
Date: October 05, 2010 06:34PM
Someone out there built a heater valve and might have one to purchase. I need one it's getting cold in Wisconsin.
flitner
John Fenner
Miami Fl
(168 posts)
03/11/2010 10:58AM
1972 MGB 350 CHEVY
Re: Heater valve for TR7
Posted by: flitner
Date: October 05, 2010 07:56PM
Show me a pic of something close I may be able to get something from work!
Single inlet/outlet or dual??
(1365 posts)
Date: October 05, 2010 10:04PM
Hey Paul, I just had a look at my tr8. It doesn't use a heater valve. Are you sure that you need one? The temp is controlled by two flaps in the heater box. Maybe you just have a broken linkage or something like that. If you do need a valve just order up one for an early VW golf. They're cheap, fit easily, they're cheap, they accept a cable and oh yeah they're cheap.
Hope that helps.
Date: October 06, 2010 08:54AM
There is supposed to be a volvo valve that is a direct replacement. Before I knew about that I adapted a 4 seasons valve but it doesn't have the temp control bulb and I had to make parts.Someone on here may have the part number or maybe find it at triumphtr7. Supposed to be available through NAPA.
JB
Oh, here's the info: [www.forum.triumphtr7.com] bottom of the page.
Dan B
Dan Blackwood
South Charleston, WV
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: October 06, 2010 10:21AM
TR7....Wisconsin? Sounds familiar.....
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Posted by: WedgeWorks1
Date: October 06, 2010 12:00PM
The TR7s & TR8s that have AC have a heater/coolant control valve. The Non AC cars do not. There is a cross over and when you find one they are a major pain in the butt to replace. Some go as far as taking the dash out so the can get to the top side of the valve to drill out the 2 rivots. Others have put a hose bypassing the valve and put a valve up in the engine bay to let coolant flow when they need heat.
(1365 posts)
Date: October 06, 2010 02:46PM
The temp compensating Volvo valve is no longer available. The conversion kit from Volvo actually consists of a VW style valve and some hoses. The kit is around $90.00 the valve alone is about $15.00
Dan B
Dan Blackwood
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: October 06, 2010 03:20PM
(1365 posts)
Date: October 06, 2010 04:22PM
Thanks for that Dan. I should have thought to check as I deal with IPD often.
