Triumph Sports Cars
77v8
Robert Dehart
(25 posts)
10/07/2010 06:56AM
Hard to find item. Aluminum flywheel for the rover v8 any one know where to buy?
Posted by: 77v8
Date: October 20, 2010 12:41AM
I only found one supplier. tsimportedautomotive thats a mouthful.
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Re: Hard to find item. Aluminum flywheel for the rover v8 any one know where to buy?
Posted by: WedgeWorks1
Date: October 20, 2010 01:00PM
Try The Wedge Shop. D&D might have one too? I hope you dont plan on driving on the street a lot with the aluminumn flywheel.
Edited 1 time(s). Last edit at 10/20/2010 08:13PM by WedgeWorks1.
77v8
Robert Dehart
(25 posts)
10/07/2010 06:56AM
Posted by: 77v8
Date: October 21, 2010 12:22AM
I do not want an aluminum only type. I want a steel insert type. thanks for the it is appreciated.
john 215
john lucas
Luton, England
(1 posts)
10/03/2010 03:42PM
Triumph TR7 Rover V8 4.6
Posted by: john 215
Date: October 23, 2010 05:04PM
Hi,
A bit far for you gents but over the muddy ditch-
[v8tuner.co.uk]
Not cheap though, even before postage.
cheers John
WedgeWorks1
Mike Perkins
(460 posts)
07/06/2008 08:07AM
Date: October 24, 2010 05:26PM
As far as I know the aluminum flywheels sold have a steel insert.
Date: October 24, 2010 10:37PM
Robert, Be easier if you stated your desired disk dia.? Single/double ? All steel for a double weighs under16 lbs." Fidanza" sells alum/steel flywheels,no Rover, but will sell "replacement"steel inserts, with bolts/nuts. I'm using for a 10.5" disk.Good Luck, roverman.
77v8
Robert Dehart
(25 posts)
10/07/2010 06:56AM
Posted by: 77v8
Date: October 24, 2010 11:22PM
I dunno guys I think ill stick with my first option at around 400$ U.S. but clutch type. Im not sure yet Ill probably go doubble plate. I have to get the engine macined now anyways. I found helicoils in the block. but my life is on pause for military training untill x-mas.
