Re: Flares for a spitfire
That's great looking. There are a few Z's with engine swaps around me. All turbo'd modern I-4's & very well done by a local shop.
i am thinking of using some very wide motorcycle rear fenders like those used on some of the choppers with very wide rear tires.now this will be just a starting point for the finished fender but it has the correct shape and the edges have a nice rounded shape.the fender is 29" long and 12" wide and will allow me to spilt it down the middle and get two flares out of one fender.now this is the good part they only cost $79.00ea. from kc cycles.this idea isn't carved in stone but it is a viable idea.
It's hard to picture how that will work. Seems like they'll stick largely straight out. You might want to make a template out of poster board to see what it's going to look like before you buy those & start cutting.
like i said it's a starting point.mostly for the round shape and the nice lip around the edge.of course they will have to be tapered into the body to give the correct look but that can be designed with poster board and tape till i get the shape i want then transferred onto steel sheet and cut and rolled /english wheel to fit.these fenders are a great place to start from as they are strong (14 gauge)and uniformly shaped .i tried to find some old volkswagon fenders and when i did they want a fortune and they still need to be cut up and shaped anyway so these as a starting point may be the way to go.
That should work really well for the inner if the radius matches up. Check out the job Terry's boys did on the Roadmaster's rear fenders. I had worked up some tin on the wheel but they re-did them and the results are surprisingly close to what I did on my '71 RD.
i bought some volkwagon rabbit front fenders to cut up and use for the front on the spit.in my case they will need widened but if you were just looking to add a small flare they are perfect and almost fall onto a spit.very litlle messing with to make them look right.as i said i have to make them wider as my front track is wider.i found them on the local want adds.brand new and i got them for $120.00 for the pair.
Gary F., If that is your Jensen Healey, would you please complete a "How it was done". JH 's need more coverage here. Thanks, roverman.
not my car m8.that was a pic sent to me from a fella on the turbosport uk site. he did the flares on the jh.the flares or arches as they call them in britian are from a mk1 ford escort rally car.those flares are still made and sold by expressed panels but would have cost me $2000,00 by the time i got the four of them shipped here to canada.a fellow by the name of gary from RETRO MOTORSPORTS did the work.he is an awsome fabricator to the lenghts i cannot describe.check out the site if you want to see some out of this world resto work of some extremely rusty cars.
