Triumph Sports Cars
ojaibuddy@sbcglobal.net
Bud White
(1 posts)
01/07/2009 11:59AM
steering column for a TR4 A conversion
Posted by: ojaibuddy@sbcglobal.net
Date: April 01, 2011 01:39AM
how do you guys rerout the steering column in a tr4 a conversion. what do you use as a universial and how many?
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Re: steering column for a TR4 A conversion
Posted by: 74ls1tr6
Date: April 01, 2011 09:48AM
This is a way that has been used with some success. Woodward steering joints.
motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
1967 Morris Minor (48 hp @ crank!), 1971 TR6 302
Posted by: motek
Date: April 04, 2011 01:28PM
I copied Calvin and it worked. Note that his is for a GM and mine is Ford. I document it here:
[www.6-pack.org]
This is on my TR6 but it should be very similar on a TR4.
George
Edited 2 time(s). Last edit at 04/04/2011 01:31PM by motek.
jdevries
john devries
grand rapids mi
(18 posts)
05/08/2011 06:06PM
1963tr4 chevrolet destroked 400 to 358cu in
Posted by: jdevries
Date: May 10, 2011 09:14PM
it can be done real easy by moving the steering shaft mount under the dash over by about 1 inch. The hole in the firewall needs to be enlarged slightly and both mounts under the dash need to be moved over as well as the hole in the dash itself must be enlarged slightly. This lets the shaft slide between the number 5 and 7 cylinder on a SBC. The clearance is tight between the steering shaft and the # 5 spark plug but mine has worked with both a straight plug and an angle plug cylinder head. This is the best shot I have of mine with out spending time to take more photos. This set up uses the stock steering u-joints and clears everything by just enough. A miss is as good as a mile.
Edited 1 time(s). Last edit at 05/10/2011 09:34PM by jdevries.
motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
Posted by: motek
Date: May 30, 2011 11:22PM
I would take John's advice. It was a ton of work routing mine (all of it hunched over) so if you can sneak the stock shaft through on a Chevy, this is the way to go.
George
