en ian jenkins Mississauga Ont canada (67 posts) Registered: 12/27/2010 11:06AM Main British Car: 77 tr7 |
TR7 rims
I have read about upgrading from 13' to 15" rims.
I'm unsure of bolt pattern and offset, etc, that work best on these cars. I was considering some ROTA RB WHEELS 15X7 4X95.25 RS Does anyone have experience with fit and clearance of the about size rim? thank you |
Re: TR7 rims
Those are the ones you want. 4X95.25mm is the same as 4X3.75". The perfect offset is +25. There is a still a chance that your tires will rub on the inner fender lips. Some guys will trim the lip a hair so they won't cut the tires. The usual tire size mounted on those rims is 205/50/15. Most guys go to the 15" rim to have access to a better selection of tires. Nobody makes a really good 13" street tire any more.
