Triumph Sports Cars
cdooley
Charlie Dooley
(1 posts)
06/21/2011 06:51PM
Positive valve seals on the TR8 V8
Posted by: cdooley
Date: June 21, 2011 07:00PM
Looking to install positive seals on my 1981 TR8 to prevent that cloud of smoke when you start up or change gears. Anyone have any luck with this?
(1973 posts)
Re: Positive valve seals on the TR8 V8
Date: June 21, 2011 07:11PM
Not TR8 but, have had good luck with Viton Perfect Circle type valve seals. Look on Ebay for Viton seals, come in different sizes. Guides need to be cut down. Mr Gasket makes a cutter for your hand drill. I just put them on the intake and use the O rings on the SBC exhaust valves.
bsa_m21
Martin Rothman
Vancouver, Canada
(205 posts)
01/06/2009 11:41AM
1980 TR7V8 Rover 3.9L
Posted by: bsa_m21
Date: June 22, 2011 11:11AM
Install new rover v8 (3.9, 4.0, 4.2) intake valves guides and seals. Cheap and easy to do as they are a straight exchange. Change your exhaust guides while you are at it as they are probably worn also, but don't worry about seals. Intake sucks oil down the guide, exhaust blows up, not down the guide.
M.
(5812 posts)
Date: June 22, 2011 11:39AM
I like teflon seals on the intakes and umbrella seals on the exhaust. Even valve guides need a little lubricant.
JB
(2986 posts)
Date: June 22, 2011 12:23PM
Charlie, Valve seals will not replace worn away guides. Putting new seals on worn guides, will cause short term failure of the seals. Good Luck. roverman.
