Dan B Dan Blackwood South Charleston, WV (973 posts) Registered: 11/06/2007 01:55PM Main British Car: 1966 TR4A, 1980 TR7 Multiport EFI MegaSquirt on the TR4A. Lexus V8 pl |
Re: TR7 Brake Booster
Ian,
Check out Rodney's 1is build in "How it was done."l Dan B |
Not sure about that. Usually Holden is stock GM stuff I think.
I installed one into my buddies TR8 for him several years ago along with a 1" master and an adjustable proportioning valve. It works very well. I had to open up the mounting holes a little, but nothing too difficult. I think he picked it up from Summit.
en ian jenkins Mississauga Ont canada (67 posts) Registered: 12/27/2010 11:06AM Main British Car: 77 tr7 |
Hi Todd
I saw that Summit has alot of different set ups. did you install a 7" single diaphram unit or was there room to fit in an upgrade? |
It was slightly bigger than was the TR8 booster I removed, which is slightly bigger than the TR7 booster. Hope that helps. Your limited on the outside diameter because of the windshield scuttle hanging over the top of the booster. If you go much bigger, it won't fit. We fitted the bigger unit on his car for several reasons. The main reason was because he went to bigger 4 piston Willwood calipers in the front and stock Ford calipers on the back. We also fitted a rear end out of a Lincoln with 12 inch rear discs. We needed to go to either a 7/8 or 1" master to push that much fluid. The unit we installed was the cheapest best solution to meet all of the needs the car had. The adjustable proportioning valve came mounted under the booster and made dialing in the brakes easy. I plan on installing something similar on my car as soon as I can get around to it. It has Willwoods all around, and the stock master has way too much travel.
Sorry, i tried to post a picture but looks like its too large an image
Anyway, dual diaphram booster fit okay Looks as if an 8" diaphram would fit if windshield wheel box cover was modified |
HI I put in an universal 9 inch booster and a 7/8 master. The got rid of the stock proportioning valve for a Willwood adjustable one. It works good can lock up all 4 wheels. All for less than 200$.
