Coil over conversions
My TR4A needs attention in the rear shock department. Coil overs appear to be the best option, but the Revington kits are waaay to expensive. $669 at TRF!
Does anybody know what shocks they use? It doesn't look like it would be that hard to fabricate your own, if you had the right specs for shock travel. I remember seeing a RATCO kit a while ago, but can't find them now. |
Re: Coil over conversions
RATCO is a British V8 sponsor!
Contact info for all our sponsors can be found in our Vendor Director, which is easily navigated-to from anywhere on the British V8 website by pointing your mouse at the "Contact" pull-down-menu button at the top of each page. Or... here's the direct link: British V8 Vendor Directory Here's their banner ad: |
p.s.: When talking to our sponsors, please thank them for their support of British V8. Let them know you found them here. Their ads keep British V8 online and growing!
Dan,
I have the Revington kit. I will take one of the shocks out....check the amount of travel. When I installed them..the shock travel was not that much. The shock has about 12 or so settings that can be set using a allen wrench. I don't know if these will work on the TR4 unless you have the IRS suspension. I think it would be fairly easy to fab the brackets and other parts....then just purchase the shock replacement. You might be able to purchase right from Revington (shock). Your spring needs to be at lease in the 450lbs range for the shocks to not take all the stress. Maybe I can scan the instuctions and post them here. My post shows how this was all installed. [forum.britishv8.org] Calvin |
Calvin, that is awesome! Thanks!
The TR4A (mine) does have IRS, identical to a stock TR6, the only difference is the wheel and tire size. You had the body off the frame when you did your conversion. How hard do you think it would be to do it with the body on? |
The AVO model number give an indication of length, with the first number being the open length and the second number the closed length, e.g. 140/95 is 14 inches open and 9.5 inches closed. Do you see number on the shox?
I still need to pull the shock out to find the model number... or I can E-mail Revington for the model number of the shock...just thought I was going to be off today.
As for installing the coil over conversion with the body on....I believe it could be done. The hard part to install would be the shock mount round plate (welding in)...that has an offset hole so the shock threads won't interfear with the body. The round piece of steel with the hole thats offset (In pic that has the whole kit above)....I put on top of the spring tower and welded from the top side. Might be able to do this with the body on. Both the trangle pieces of metal to strenghen the spring tower ...should be able to weld in with the body on. I would remove the trailing arm or let it hang down as far as possible (would need to remove half shaft & hub assembly, lever shock etc. A cheap way if you are still using your original lever shock to get a better ride...get the uprated spring for the valve shock. I used them in my TR250 and the ride was tight in the rear. If you are using the rear shock upgrade with KYB, Spax or Monroe.....I used the bracket and ran a lenght of treadsall rod through the trailing arm hole (hole for original lever shock link) and up to the bracket to compress the spring for the coilover kit (compress to get shock mounted on top plate and nut on). |
I can't use a lever shock on the passenger side anymore without doing some repair work. The old ones worked loose enough to wallow out the holes, and eventually broke the ear off one side of the shock. The other side has an inch long slot where the hole should be. On the mounting holes, they are somewhat elongated as well. So it looks like the coil-over is the best solution.
I was looking at the photos, and wondering about the crescent shaped plates that go under the springs. Do those go into some kind of recess, or would it be possible to use a one piece ring there? I was thinking that if you could do that it wouldn't be that hard to cut those out with a pair of holesaws. Suppose you used a blank for the bottom, again cut with a holesaw and then notched for the protrusions in the LCA and the center hole drilled for a stud mount shock. Do you think that would work? Seems like it'd be a little easier to make.
Welding in that top disc on the bottom side instead of the top should work. Might not exactly be easy but if the car was jacked up at a steep angle that should help. Jim |
The cresent shape plates that go under the springs in the trailing arm spring hole.....If you took a dremel tool with a mini grinding wheel...you could grind off the casting and make it flat...you could use a full ring in there...also on the bottom of the trailing arm grind off the hump on both sides and make it flat....a ring mount with the bracket welded on for the bottom of the shock mount would work.
As for the round top piece being welded in from the bottom (for top shock mount).....it will shorten the distance about a 1/4 inch or so between both mounts. I don't think this will cause any problems. A stud mount shock would work for both ends of the shock...using Jims idea. The hole in the trailing arm for the shock just open up with a rat tail file for shock movement.....could even use the bottom plate for an adjustment for how long the shock was being used...just make some extra blanks(shim rings) and use a flat round plate with a hole in the center for the shock stud on the very bottom. Calvin I think flat metal rings would make the casting area stronger after making it flat on both sides of the trailing arm spring hole. Edited 1 time(s). Last edit at 04/21/2008 08:28PM by 74ls1tr6. |
I believe the TR4A trailing arms don't have those ridges. It looks like maybe they were drain holes or something. Perhaps they discovered water and stuff collecting in the bottom of the spring and added those to the casting. I'll post some pictures in a couple of days, and do some measuring. Can't do it tonight, my daughter has a strings concert.
Question Dan?
Is the frame holes and threads OK where the lever shock's bolt up? Both side's? Is the trailing arm OK where the lever shock links bolts in? Both side's? If all is OK ...Then all you need is a set of lever shocks right? |
OK!
Idea!!....think it would be possible to heli-ciol the threads? If that can't be done....how about welding on the bracket for the shock conversion? I think that could be done....I know it would be kind of a fixed part of the frame (welding the conversion bracket in) but a lower cost way to go. Shocks wouldn't burn a hole in the $$ either. I think it would be fairly easy to weld in if everything was out of the way (axles, diff, and e-cable) I think the bracket could be made with 1/4" steel if you had mock up of the bracket! Your thoughts?? |
Are there negatives of going to shocks inside the coil springs? I know there are a lot of tube shock conversions available that use those brackets, but I think if I was going to fix the mount holes on the frame I probably would try to find a replacement lever shock on ebay or something. I might even have one somewhere.
The front shocks for a 94-96 S10 2wd match what I need in terms of travel and measurements, 12.25 extended, 8.375 compressed. Using 1/4" plate for the bottom mount shifts everything downward 1/4" to give me the 12" I need for the half shaft not to rest on the frame when the car is jacked up. The only thing being that the rubber stops on the body will be doing more work if I ever bottom out the springs. I don't have the bumps you have in the aluminum casting, so it looks to be a pretty easy fabrication. It would be a much bigger pain to weld on the old mount than it would be to weld to the top spring mount. |
The coil overs would be the best ride of all.There are some things to consider.
If you have a spring that doesn't have enough spring tension or lbs rating.....and the car bottoms out...the shock may punch out or through the top plate that holds the shock. [www.goodparts.com] The AVO shocks that come with the kit are 10" fully extended. I used Richard Goods lowering springs that are a little uprated. I weight about 215lbs...stood on the rear of the frame and moved my weight up and down to see the travel...maybe about an 1" travel at best for the suspension movement. My thoughts would be that the spring should do most of the work and the shock should do the dampaning. It would depend on your spring and shock that is used to get the right setup. Good Luck!! and post your end results. |
