sellersrodshop Steve Sellers Nashville TN (21 posts) Registered: 10/24/2010 02:00AM Main British Car: 1966 Triumph TR-4A |
early tr4 chassis info needed & brake question
hey guys! been a while since i've posted anything, but think i'm finally going to get time to start my project soon... started doing some research & have determined my tr4a body is actually setting on a early tr4 chassis. is there anything that is inherently weak on the early front suspension that would need to be upgraded? i don't see much difference other than the upper ball joint looking like a large tie rod end & also that the early lower trunnion doesn't have the castor upgrade.
also have a brake question. i was leaning towards doing the cressida rotor/4runner caliper upgrade in the front & having the hubs redrilled for the 5 lug small ford pattern. in the rear, i am narrowing an explorer 8.8. i noticed during research, that the stock explorer rotors are approx 1/2" larger diameter than the cressida fronts. will i run into any problems with this or will the adjustable prop valve handle it? i think i'll be fine with caliper piston volumes front to rear & may look into swapping the rear brakes for the v6 mustang setup if it will bolt on to the explorer rear axle. here are the rotor sizes & caliper piston sizes for each: cressida/4runner front: rotor diameter 10.6" caliper pistons 1.68" & 1.33" explorer rear: rotor diameter 11.22" caliper piston 1.81" mustang rear: rotor diameter 10.51 caliper piston 1.49" |
Re: early tr4 chassis info needed & brake question
Steve, The Explorer rotor is larger diameter because the large hat(drum) emergency brake. You probably don't want 4 lug in front and 5 lug in rear. Easy to redrill Ford 5 lug to 4 lug(same circle).Use one existing lug and opposite is exactlly centered between two existing holes. The other two are close to existing holes but work fine.
Edited 1 time(s). Last edit at 02/04/2012 04:28PM by mgb260. |
just to clarify, i'm changing the lug pattern up front to 5 lug small ford to match the rear end (already have the wheels in 5 lug). am also planning a few extra braces & such after i get the new motor set in place to check clearances etc.
I know i'm reviving my old post. progress doesn't move too fast around here lately & I've been trying to finish up my mustang project before getting too deep into the triumph. I've located some of the later type upper & lower control arms etc. but still cant get a definite "yes" or "no" as to whether they will be a bolt in swap on my early chassis or not & if the extra castor set into the later trunnions is worth it or not on these cars... hoping to hear something before I go to the trouble of picking them up. thanks!
