sellersrodshop Steve Sellers Nashville TN (17 posts) Registered: 10/24/2010 02:00AM Main British Car: 1965 Triumph TR-4A |
ford 5.0 fuel pump
has anyone been able to run a manual fuel pump on the ford motors or does it interfere with the steering linkage? i'm in the process of getting things together to rebuild the gt-40p 5.0 & was curious what everyone was doing. i'll be going to the early style timing cover to use the standard rotation water pump/v-belt setup so now would be the time to add the fuel pump eccentric if manual pumps are feasible.
also, are most using the early front sump oil pans? i would like to go as shallow as i can with the pan to get the engine low to accomodate the EFI should i ever decide to reinstall it. thanks! |
