Maņana Steve Wten Toronto Canada (18 posts) Registered: 02/28/2015 01:35AM Main British Car: 1978 Triumph Spitfire 1991 Miata 1.6 |
Re: Miata 1.6 into a 78 Spitfire
Joe, this looks really cool.
Sorry to hear about the rust, but really like the way you're thinking with the suspension. That's similar to my train of thought, and of course there have been many before us with the same starting point. At first I thought that the plates you mount the diff to might not be enough, however, they're really not bearing any vehicle weight, just the diff, so should be good. Wishbones look like good geometry, I'm thinking to somehow get the coilover mount inside the lower A-arm. I know lots of cars have them outside, but it's a goofy hang-up of mine. Did you have to cut up the tub at all to fit in the second row of rear lateral framing? Really nice to see this. (thumbs up emoticon!) |
Thanks Steve. Means a lot coming from you considering I have been studying your website and copying as best I could - your site made the transition to the 63 much easier - that's absolutely true. Yes, unfortunately it did require cutting into the cabin area but not as much as I first thought - but still hated doing it. Due to the placement of the springs, I had to cut just into the base of the rear deck by about an half inch. Springs could have probably fit on the inside of the lateral framework with professionally designed A arms. Honestly, I just went with what I thought I could do safely and with least cost.
I figured you may have had to, but it definitely looks close.
I've been thinking about cutting a swath out of that area, specifically the vertical part and moving it forward; of course I think that that part contributes much to strength so hopefully I could recreate that strength further forward. That would reduce the area available behind the seat, but make more room for the suspension. Could even cut a bit more out front and then weld that in below the gas tank, or just fab something similar. Just thinking out loud. But if you just cut a bit off the corners and managed to sneak that new frame assembly in, that is simpler and likely stronger than I could do. Keep it up Joe, looking forward to whatever you're willing to share. |
Need some wiring help!! PLEASE!! Running, moving, stops @ but this wiring!! GEEZ!!! How can I identify which wires I can delete AND fan wiring. Trying to attach photos if I can get them smaller.
Hey Joe,
This is what I put together for mine... Can be found here as well.... [stevew10.wixsite.com] |
Hey all. Does anyone know how to get in touch with Doug? I'm actually thinking about picking up the miata spitfire he built, and I wanted to speak to him about it and other pitfalls he happened to come across, and possibly purchase his notes and diagrams from him incase something went wrong, so I'd have a place to start. If anyone has his contact information, I'd greatly appreciate it. It seems like he hasn't been active here in a long time.
Thanks! |
Is there a full schematic of the 1.6 Miata wiring harness that is needed to install the a 93 Miata engine to a spit that any laymen can read and understand, PLS
i see my beast is up for sale again on NJ Craigslist. Funny to see it up for sale every so often. it seems to be a bit worse for wear then when i sold it.....This is Doug under a new login.
i sold it several years ago for $3,000.....if they did what they said, particularly rebuilding the exhaust it might be a good deal. It could use a paint job at some point. glad to see it's still alive and kicking. That Miata engine and tranny in it really transformed the car. i hope all my wiring diagrams are still with it-or someone will be in for fun if something goes out!
