Triumph Sports Cars
Goto Page: 123Next
Current Page: 1 of 3
v869tr6
Ed Olson
(81 posts)
10/25/2007 09:54PM
69 TR6 487 CI Pontiac
What modern inline engine would you put in a TR6?
Posted by: v869tr6
Date: January 19, 2013 07:02PM
I have a issue with my TR6 engine and may install a modern engine.
What I want
Easy to install
Stock but having a turbocharged version would be a plus, for a later upgrade.
150 to 200 HP
Easy to set up 5 or 6 speed
4, 5, or 6 cylinder
So far it looks like a Colorado 4 or 5 cylinder might work well, but don't know if I can put a stick
behind the 5 cylinder or if the ECU computer will run stand alone.
Any input?
britcars
Phil Ossinger
New Brunswick, Canada
(346 posts)
02/02/2009 07:58PM
1977 MGB Roadster, Rover 3.5 ADVENTURE BEFORE DEMENTIA!
Re: What modern inline engine would you put in a TR6?
Posted by: britcars
Date: January 19, 2013 10:36PM
If I remember right, that GM Atlas engine is very tall - 30" from bottom of pan to the top of engine. Not sure of the length and width of the 5 but the 6 is about 32" long. They do make godd power and lots of torque. Thought about one of the BMW inline sixes? There are quite a few around with Ford small blocks in them. Check out the How It Was Done Section of this site.
Edited 1 time(s). Last edit at 01/19/2013 10:38PM by britcars.
v869tr6
Ed Olson
(81 posts)
10/25/2007 09:54PM
Posted by: v869tr6
Date: January 19, 2013 10:45PM
Didn't really think about the atlas being to tall thanks, thats what I need.
I have a V8 TR6 now, but had a second TR6 follow me home. LOL
BWA
(345 posts)
04/13/2010 08:13PM
Posted by: BWA
Date: January 19, 2013 11:43PM
Does the engine have to be an inline 6?
I am putting a 2003 GM 3400 V6 in my TR6 and it fits quite nicely, it bolts up to a Ford T5 transmission. This engine will put out about 210 hp at the flywheel. If you went this route I would recommend the GM 3500 as it has an extra 25 hp and it is the same physical size as the 3400. This swap involves no cutting of the firewall and I am using the existing TR6 engine mounts. The steering shaft needs to be moved over a bit to clear the header.
I bought the parts to convert this FWD engine to RWD from British Car Conversions in Dayton Ohio. Check out their website.
Byron
socorob
Robbie
La
(173 posts)
09/17/2009 04:42PM
Posted by: socorob
Date: January 20, 2013 09:07AM
make sure you choose something that has aftermarket support. Im stuck with an engine thats getting less and less available for it. and when you can find something its used and expensive. I like the gm v6 or ford duratec 4. The 2.5 version can be had with 170 hp/tq factory and an be built to mid 200 hp+ NA and is light. If you want to go turbo 4, theres lots available for the nissan sr20. If you want to spend big bucks you could go for the supra or skyline straight 6.
tr6turbo
Dale Knapke
Sidney, Ohio
(169 posts)
08/24/2008 09:44PM
1972 Triumph TR6 Ford 2300, 4 Cyl Turbo
Posted by: tr6turbo
Date: January 20, 2013 10:09AM
Look up Dale Knapke in the photo section of this form for a 2.3 turbo Ford in a TR6.
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Posted by: MGB-FV8
Date: January 20, 2013 07:17PM
Modern engine with speed parts, readily available, and strong support, I would have to go Miata 1.8L or 2.0L. These four cylinders enjoy all sort of available turbo kits or superchargers and also all sort of O.E. ECU or aftermarket stand alone systems. I have a friend that installed one of these (Miata) turbo four banger in his T-bucket and it pulls 300 horsepower at the rear wheels. IMHO, it's an all around winner for your TR-6......
socorob
Robbie
La
(173 posts)
09/17/2009 04:42PM
Posted by: socorob
Date: January 20, 2013 10:07PM
[www.mazdatalkforum.com]
The mazda mzr/ford duratec use the same block. There are differences in block height between the 2.0 and the 2.3/2.5. Heres a guy who put the 2.5 into a miata and has mid 200hp.
alana
alan atkinson
10567
(232 posts)
06/19/2008 08:06PM
68 TR250 LS2
Posted by: alana
Date: January 21, 2013 09:00AM
Ecotec fits nicely.
Long thread, but you'll get the idea...
[www.6-pack.org]
Or a 2JGZE
[www.6-pack.org]
v869tr6
Ed Olson
(81 posts)
10/25/2007 09:54PM
Posted by: v869tr6
Date: January 22, 2013 07:27AM
Wow, lot of responses thanks.
The SR20 looks good as far as price go's from one of the JDM suppliers.
The Ecotech is the small block Chevy of 4 cylinders. The Saab turbo 2L at 210 HP looks to be a little better price then the 260 HP models.
The Ford 4 cylinder, new and old both look good.
So many choices.
(6576 posts)
Date: January 22, 2013 08:13AM
A 4 cylinder in a TR6 just seems wrong.
socorob
Robbie
La
(173 posts)
09/17/2009 04:42PM
Posted by: socorob
Date: January 22, 2013 12:25PM
I know what you mean, but a lighter more powerful, more reliable engine can't be a bad thing, even If it has 2 less cylinders.
v869tr6
Ed Olson
(81 posts)
10/25/2007 09:54PM
Posted by: v869tr6
Date: January 22, 2013 02:51PM
A 4 cylinder in a TR6 does seem odd, but if I do the math on two TR6's I have one V8 + one 4 cylinder / by 2 = 6 cylinders
If I can find a nice inline 6 I may still go that route, but I do like the idea of a lighter weight higher powered engine. The parts in my TR6's get run very hard, as I am sure the rest of the people on this site do to their cars, the stock hi compression ( shaved head ) engine beat up a rod bearing after 3 days of pounding the car at Brainard Intnational Raceway during the Powercruse.
Before this TR6 was found on a internet auction by accident , I was planning to get a Solstice or Sky as a nice weather driver.
(6576 posts)
Date: January 22, 2013 03:43PM
There's got to be a good alloy block inline six out there. Volvo comes to mind but didn't Nissan have a really good six?
How about the 2JZ?
Ford Australia's Barra 4.0L Turbo?
S54?
Or perhaps the 4.2L TVR Tuscan?
Edited 4 time(s). Last edit at 01/22/2013 04:09PM by BlownMGB-V8.
HealeyRick
Rick Neville
(495 posts)
12/19/2007 05:01PM
Posted by: HealeyRick
Date: January 22, 2013 04:36PM
I really think this would be the ultimate:
http://i49.tinypic.com/5mzp75.jpg
[bringatrailer.com]
socorob
Robbie
La
(173 posts)
09/17/2009 04:42PM
Posted by: socorob
Date: January 22, 2013 06:25PM
The Nissan RB inline 6s and the Toyota straight 6 are very nice but. $$$.
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Posted by: MGB-FV8
Date: January 22, 2013 09:13PM
I though that his requirements were turbo, easy set up, and ECU adaptability?!?!?! Miata has it all!
v869tr6
Ed Olson
(81 posts)
10/25/2007 09:54PM
Posted by: v869tr6
Date: January 22, 2013 09:52PM
Keep them coming, the choice is still wide open at this point. The Ecotech superchaged install looks like a pain due to the placement of the supercharger. Looks like many of the straight 6's are also wide on the steering side. That BMW looks cool is there a build write up?
BWA, what T5 did you get and does it line up as far as the shifter go's? And that is a 60 degree engine?
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Posted by: MGB-FV8
Date: January 22, 2013 09:55PM
Good luck with the BMW electronics (ECU) ;)
BWA
(345 posts)
04/13/2010 08:13PM
Posted by: BWA
Date: January 22, 2013 10:15PM
Ed the T5 is a Ford Racing transmission that is for the 1979 to 1993 Ford Mustang V8. The 3400 3500 engines are 60 degree engines and are quite light they have aluminum heads; the engine would weigh about 320 pounds.
The center of the shifter is about 1.5" back from the center of the original shifter.
Byron
Goto Page: 123Next
