Ivan Ivan Ingram Manitoba (13 posts) Registered: 04/17/2011 02:43PM Main British Car: 1963 Triumph Spitfire 2.3l ford I4 hopefully |
Turbine powered spitfire (not mine)
I found this wildly impractical and totally delighful build log today. A student team is installing a helicopter engine into a Spitfire.
[www.stanceworks.com] Edited 1 time(s). Last edit at 03/28/2013 09:37PM by Ivan. |
Re: Turbine powered spitfire (not mine)
Fantastic. A while ago I saw, ummm, was it a Porker, with a helicopter engine. It drove, it was in use. All quite bonkers.
Ivor |
Is nothing sacred ?? Did they even consider what will happen to the "Resale Value". Is "this thing" ok, just because Rover experimented with turbines ?? Will it became a "Porker" ? How do I get to drive it ? Is it for Leno ?? Redline is ? Also, thank you for this "up-lifting" story. roverman.
Edited 1 time(s). Last edit at 04/01/2013 07:55PM by roverman. |
