Triumph Sports Cars
Goto Page: Previous123456789Next
Current Page: 7 of 9
Dan B
Dan Blackwood
South Charleston, WV
(1007 posts)
11/06/2007 01:55PM
Re: TR7 LexusV8 conversion
Posted by: Dan B
Date: November 06, 2016 08:25PM
We had a plumbing error and were not getting fuel. In the process of replumbing, the pump fell and broke. The car is running on gas from a squirt bottle
dwtr6v8
Don Watson
West Virginia
(305 posts)
12/07/2007 07:45AM
1974 TR6 Ford 5.0 HO
Posted by: dwtr6v8
Date: November 07, 2016 11:03AM
Sounds Good. Sorry about the pump! Maybe you need a good hands man like me.
Dan B
Dan Blackwood
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: November 07, 2016 01:06PM
You working for State Farm now?
Dan B
Dan Blackwood
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: March 19, 2017 11:16AM
Plans are to work on the TR7 this weekend and bring it back to WV on Sunday. Then I can take it to a local muffler shop here and get exhaust put on it. Jim says it runs, so we need to do a little tuning. Also the HTOB needs a seal kit, so the tranny will have to come out this weekend.
(4512 posts)
Date: March 21, 2017 10:52AM
Looking forward to it, Dan!
dwtr6v8
Don Watson
West Virginia
(305 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: March 21, 2017 11:54AM
Getting close my friend! Which will be quicker....your TR7V8 or my TR6V8?
Dan B
Dan Blackwood
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: March 22, 2017 06:10PM
You have a liter on me, plus the TR6 is probably lighter.....
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: March 22, 2017 09:41PM
Dan, do you think we're going to see it running at the meet? 😊
dwtr6v8
Don Watson
West Virginia
(305 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: March 23, 2017 09:08AM
Well thank you Dan, I did lose a little weight.
You are going to have a very sweet ride!
Dan B
Dan Blackwood
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: March 23, 2017 11:25AM
Scott, I plan to have it ready by June. I am bringing it home from Jim's on Sunday, so I will have it here, so unless I break something between now and then it should be good to go.
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
Posted by: Scott68B
Date: March 23, 2017 05:02PM
Looking forward to seeing it Dan! Take some video this weekend!
Date: March 24, 2017 03:50AM
Congrats Dan. That's probably the most fun time of a conversion... We'll, maybe 2nd most... just behind driving it the 1st few times!
Dan B
Dan Blackwood
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: March 26, 2017 10:04AM
(2463 posts)
Date: March 26, 2017 03:31PM
Dan, Congrats!
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
Posted by: Scott68B
Date: March 26, 2017 07:41PM
Congratulations Dan!!!
Dan B
Dan Blackwood
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: March 27, 2017 06:21AM
Here is a video highlight of the weekend. Thanks to Carl for shooting most of it on his phone.
[youtu.be]
Edited 1 time(s). Last edit at 03/27/2017 06:21AM by Dan B.
(6469 posts)
Date: March 28, 2017 10:57AM
That's an excellent video clip Dan. But then I guess it would be considering whodunnit. So... pipes and mufflers, and there's little doubt it'll be at the meet in Lewisburg. OK, I'm envious....
(6469 posts)
Date: March 28, 2017 11:36AM
One of the tricks we needed was a pedal stop for the clutch. When fully depressed the clutch re-engaged and would not allow Dan to shift it into gear. But a test drive showed that it would fully disengage halfway down. We welded a fabricated nut plate to the back of the clutch arm (done in the car) and added a 3/8" carriage bolt and lock nut to stop the pedal halfway down and all was good.
We also found a new failure mode for the HTOB. (Which was in fact just fine. We did install the new seals anyway.) Because the feed line had not been pulled all the way out of the bellhousing it had a loop and got up against the pressure plate. So once the engine had been started it stripped the braided sheath and holed the liner. Found a stray hose in spares and fixed that easily enough.
What Dan's video doesn't show, is that this car is going to be FUN! Dan, Carl and I all drove it down the driveway and back. We all got silly with it. I'll be sweeping gravel off my driveway for a week! Dan sat on the hill and tried to use up his aged, hard, and way too small rear tires all in one go. Luckily the rubber was so old that it mostly left powder which the rain has washed away but there's still a mark that will be there for awhile.
The initial tune was surprisingly close and he can drive it like that with no problem. There is a little work to do to enable the radiator fan control and get the IAC going, and the warmup is too rich, but he should have no problem driving it down to the muffler shop. After that? Well Dan, just watch that right foot until you get some real tires under it.
(1365 posts)
Date: March 28, 2017 12:47PM
Pretty cool guys.
Let the fun begin!
(4512 posts)
Date: April 25, 2017 12:50PM
Just wanted to say that this project was a blast to be a small part of & to watch Jim work his magic.
Now Dan's TR7/8 has a proper engine!
