Icekottarinn S. Markus Johannsson Reykjavik, Iceland (35 posts) Registered: 07/17/2011 07:47PM Main British Car: Triumph Spitfire Mark III 1968 1300 |
Rear suspension - Coil overs for Spitfire Mk3?
Triumph Spitfire Mk3 1968 powered by Hayabusa engine.
Upgrade of the rear suspension: I have decided it was time to upgrade the rear suspension with a full CV jointed axle setup along with another diff with LSD and better ratio (3,55:1). The Leafspring, diff and the swing axles will be removed and my goal is to go the full independent rear suspension route. These modifications will be custom made. But, I have not found the right suspension yet, i.e. I am looking for Coil Overs or a good solution for the rear suspension. Any good advice's greatly appreciated. |
britcars Phil Ossinger New Brunswick, Canada (344 posts) Registered: 02/02/2009 07:58PM Main British Car: 1977 MGB Roadster, Rover 3.5 ADVENTURE BEFORE DEMENTIA! |
Re: Rear suspension - Coil overs for Spitfire Mk3?
QA1 is a US company. I have their coilovers in my 4 link system. It may be easier for you to access GAZ shocks and coilovers as they are a UK based company.
strange engineering make a nice 12 point adjustable for a decent price. I have them front and rear in my 69 spit but the car is not finished yet and is a v8 swap so what I run for springs is of no help to you.
