Triumph Sports Cars
pjetri6@aol.com
paul estock
Loveland Colo
(4 posts)
12/07/2010 09:28PM
1955 MGTF Chevy 350
engine mounts for rover engine to Triumph TR4
Posted by: pjetri6@aol.com
Date: January 31, 2016 02:34PM
Hello, anyone out there know of someone who makes engine and trans mounts for a Rover 3.9 engine and a 5 speed trans from a Triumph TR7-8 into a Triumph TR4. I have seen several suppliers that make them for a MGB, but have not come across pre made mounts for the Triumph. I would be thankful for any help. Thanks again, Paul
tbo
Tim Body
St Thomas Ontario
(221 posts)
01/27/2013 06:47PM
Re: engine mounts for rover engine to Triumph TR4
Posted by: tbo
Date: January 31, 2016 08:22PM
You can check out the numerous builds here on the website . Lots of swaps Rover into TR4 and TR6 same frame basically . Lots of pictures too of custom mounts. You may find a supplier through checking out the installations. It will give you some good tips also.
pjetri6@aol.com
paul estock
Loveland Colo
(4 posts)
12/07/2010 09:28PM
1955 MGTF Chevy 350
Date: January 31, 2016 08:32PM
Thanks Tim, I have read quite a few messages on the website. Unless I missed something I have not seen the info I am looking for, that's why I posted this message.
BWA
(345 posts)
04/13/2010 08:13PM
Posted by: BWA
Date: January 31, 2016 08:42PM
Try sending a pm to this guy as he put a Rover engine in his TR6.
[www.britishv8.org]
Byron
Dan B
Dan Blackwood
South Charleston, WV
(1009 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: January 31, 2016 10:37PM
There is a little difference in the motor mounts between a 4A and a 6, and the front part of the frame on a 6 is a little different, so take that into account as you do your research.
Royal
Roy Owens
(2 posts)
08/31/2019 01:51PM
Posted by: Royal
Date: August 31, 2019 02:18PM
Hi, I'm new here so I may not be searching right but, I could use some help with info on Motor Mounts for a Rover 3.9 going in a TR4A solid axle. I searched several ways but can't seem to find and usable info / photos.
Thanks,
Roy
(4628 posts)
Date: September 01, 2019 12:17PM
I've not seen any offered. Likely have to make your own.
Royal
Roy Owens
(2 posts)
08/31/2019 01:51PM
Posted by: Royal
Date: September 01, 2019 04:22PM
Copy, just looking for a picture of the mounts others have used and for an idea for the best motor placement.
blue4
bill melson
(9 posts)
08/01/2014 11:52PM
Posted by: blue4
Date: February 19, 2020 08:55PM
Try D&D they advertise motor mounts for 215 that bolt to engine,they might have info about frame.
