pjetri6@aol.com paul estock Loveland Colo (4 posts) Registered: 12/07/2010 09:28PM Main British Car: 1955 MGTF Chevy 350 |
engine mounts for rover engine to Triumph TR4
Hello, anyone out there know of someone who makes engine and trans mounts for a Rover 3.9 engine and a 5 speed trans from a Triumph TR7-8 into a Triumph TR4. I have seen several suppliers that make them for a MGB, but have not come across pre made mounts for the Triumph. I would be thankful for any help. Thanks again, Paul
Re: engine mounts for rover engine to Triumph TR4
You can check out the numerous builds here on the website . Lots of swaps Rover into TR4 and TR6 same frame basically . Lots of pictures too of custom mounts. You may find a supplier through checking out the installations. It will give you some good tips also.
Thanks Tim, I have read quite a few messages on the website. Unless I missed something I have not seen the info I am looking for, that's why I posted this message.
There is a little difference in the motor mounts between a 4A and a 6, and the front part of the frame on a 6 is a little different, so take that into account as you do your research.
Hi, I'm new here so I may not be searching right but, I could use some help with info on Motor Mounts for a Rover 3.9 going in a TR4A solid axle. I searched several ways but can't seem to find and usable info / photos.
Thanks, Roy |
