Triumph Sports Cars
donkelly23
Don Kelly
Charleston, SC
(130 posts)
07/21/2011 05:13PM
1980 TR7 V8 Z28 FI ECM 4.0
Frickin thing
Posted by: donkelly23
Date: August 29, 2016 08:16AM
About ready to toss this al. lump in the trash.
New 4.0 block and fairly new heads.
Putting this thing together and the heads have been torqued down for a couple of months.
Have to remove one to send back to Woody to check a receding valve.
Removed all the nuts on the ARP studs and 9 of the washers. 1 is stubborn and won't slide off. It will rotate put that can't be the reason for my frustration.
The frickin head will NOT come off.
Next step is to get out my biggest sledge hammer and beat the crap out of it....
v869tr6
Ed Olson
(81 posts)
10/25/2007 09:54PM
69 TR6 487 CI Pontiac
Re: Frickin thing
Posted by: v869tr6
Date: August 29, 2016 12:07PM
Can you double nut the stud and take it out, that's what I have to do when the top of the bolt hole caves in on the stud.
Trying some top hat washers this time. ( washer has a 1/4" tube that gets pressed into a stepped hole at the top of the bolt hole ).
donkelly23
Don Kelly
Charleston, SC
(130 posts)
07/21/2011 05:13PM
Re: Frickin thing
Date: August 30, 2016 11:16AM
Woody says just pull all the studs...just easier.
So I'll get my socket allen tool and go to work
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Re: Frickin thing
Posted by: 88v8
Date: August 30, 2016 06:05PM
Although I hate torqueing bolts in alloy, I guess there's a reason the factory used bolts.
V8
donkelly23
Don Kelly
Charleston, SC
(130 posts)
07/21/2011 05:13PM
Re: Frickin thing
Date: September 03, 2016 02:11PM
Real busy getting ready to jet out for a while and had a minute to pull the studs.
My allen socket is 1/4 drive and boy was it a bear to turn.Gave up when I couldn't find my 1/4-3/8's
Will work on it later
